Print Spooler error 0x800706b9 printer not enough resources
2015-02-09T04:43:26+00:00
I have been trying to print for the past few day to no avail. I have gone to services and tried to manually start the stopped spooler, but this error keeps popping up. "0x800706b9 printer not enough resources". I am running windows 8.1 and I have a canon printer. I have already gone to the registry editor and got rid of the "http" in the spools folder. Please help...I desperately need to able to print.
2015-02-10T03:19:52+00:00
Hello Jason,
Thank you for posting your question on Microsoft community.
I would like to know some information about the issue so that we could help you better.
What is the make and model of your computer?
I appreciate you for providing details about the issue and your efforts towards resolving it.
This issue may occur if the installed device driver is corrupt or if the driver is not installed properly.
I would suggest you to try following methods and check if it helps.
Method 1:
Run printer troubleshooter and check. Please follow these steps:
a. Press Windows + W keys, type troubleshooting in the search box and press Enter.
b. Click "View all" and then click "Printer".
c. Click "Next" and follow on-screen instructions.
If it does not help, use method 2.
Method 2:
Please follow these steps and check the issue.
a. Press Windows + R keys, type services.msc in run window and press Enter.
b. In services, stop "Print Spooler" service.
c. In Windows explorer, navigate to the following folder location and open "PRINTERS" folder.
C:\Windows\system32\spool\PRINTERS
d. Click "Continue" or "Yes", if message prompts.
e. Delete all files in "PRINTERS" folder and then close Windows explorer.
Note: Please do not delete "PRINTERS" folder. Only delete its contents.
f. Open services, and start "Print Spooler" service.
I hope this information helps.
Please do let us know if you need any further assistance.
Thank you
40 additional answers
    2015-07-01T02:43:32+00:00
    Has anyone found a fix for this problem? I am having the exact same thing occurring.  It seems like this is unsolvable :)
    2015-05-05T15:23:09+00:00
    Hello Lisa,
    Thank you for replying.
    I am sorry for late response.
    I appreciate your time.
    I would suggest you to refresh Windows and check if it helps.
    Refer this article:
    How to refresh, reset, or restore your PC
    http://windows.microsoft.com/en-US/windows-8/restore-refresh-reset-pc
    Note: Apps you installed from websites and DVDs will be removed. Apps that came with your PC and apps you installed from the Windows Store will be reinstalled. Windows puts a list of removed apps on your
    desktop after refreshing your PC.
    Thank you
    2015-04-24T15:12:47+00:00
    I am having all of the exact same issues following the 8.1 update. Have tried all of the fixes (even bought a new printer) and there is no resolution. Looking forward to more info.
    2015-04-12T15:21:34+00:00
    Unfortunately the printer spooler refusing to run seems to not be resolved by Roger Lu's "solution".
    Tried uninstalling and then reinstalling (with the registry entry deleted) and still, the HP installer returns an error code 1603 at 95% ... most likely because the spooler isn't running. Of course as the topic of this exchange already noted, the spooler refuses to start with error 0x800706b9 (resources).
    The problem persists regardless of what I do (including clean boot, different account etc.)
    I noticed the computer to have another issue, where the Windows Update and the Store can't seem to connect to the server, while all other programs (including Metro Apps) don't seem to have any issue connecting. (I already cleared the Firewall and tried it completely turned off etc.)
