Below is an extract of the CBS log file after a KB3033929 manual installation failure. With my limited knowledge, it appears it fails to copy (C:\Windows\boot\PCAT\bootmgr) to the System Reserve partition which when I installed Windows 7, created a 100 MB
partition. I believe the error 0x70
indicates there is no space available on the partition.
This may the reason some Windows 7 updates fail the KB3033929 installation, while some have no problem.
Can you or anyone shed any light on the log entries and how I might fix the problem, or is this a M/S problem caused by installing Window 7 SP1 and only creating a 100 MB partition that should have been larger? Is there a way I can expand the partition
size without destroying my Windows 7 system ?
CBS LOG FILE EXTRACT:
BFSVC: BfspCopyFile(C:\Windows\boot\PCAT\bootmgr, \\?\GLOBALROOT\Device\HarddiskVolume1\Boot\bootmgr) failed! (Attempt 60 of 60) Last Error = 0x70BFSVC:
Error copying boot files from C:\Windows\boot\PCAT to \\?\GLOBALROOT\Device\HarddiskVolume1\Boot! Last Error = 0x70"][gle=0x80004005]
2015-03-20 14:34:01, Info CSI 0000002c Calling generic command executable (sequence 2): [24]"C:\Windows\fveupdate.exe"
CmdLine: [35]""C:\Windows\fveupdate.exe" /memtest"
2015-03-20 14:34:01, Info CSI 0000002d Done with generic command 2; CreateProcess returned 0, CPAW returned S_OK
Process exit code 0 resulted in success? TRUE
Process output: [l:248 [248]"BitLockerUpdate: Running.BitLockerUpdate: Service request is for memtest.exe.BitLockerUpdate: BitLocker Drive
Encryption is not turned ON on the OS volume.BitLockerUpdate: No servicing was performed on the OS volume.BitLockerUpdate: Done."]
2015-03-20 14:34:01, Info CSI 0000002e@2015/3/20:19:34:01.770 CSI Advanced installer perf trace:
CSIPERF:AIDONE;{81a34a10-4256-436a-89d6-794b97ca407c};Microsoft-Windows-BootEnvironment-Core-MemoryDiagnostic, Version = 6.1.7601.18741, pA =
PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral,
PublicKey neutral;34776454
2015-03-20 14:34:01, Error [0x018007] CSI 0000002f (F) Failed execution of queue item Installer: Generic Command ({81a34a10-4256-436a-89d6-
794b97ca407c}) with HRESULT HRESULT_FROM_WIN32(14109). Failure will not be ignored: A rollback will be initiated after all the operations in the
installer queue are completed; installer is reliable (2)[gle=0x80004005]
Based on the results of my CBS.log file, I decided to spend some time to re-visit this issue today. My failure seems to point to the update being unable to write a file to the system reserve partition as it was full. It was set up for 100 MB when I installed
Windows 7. Using Partition Wizard (free), I expanded the system reserve partition from 100 MB to about 400 MB. I again ran the manual installation file for KB3033929 and it installed without any problems.
After it was completed, I again plugged in my second HD with Windows XP, reset my boot loader with EasyBCD and all is now back to normal with dual boot menu to either Windows 7 or Window XP.
Finally....hope this might work for others that are having a problem.
