Page fault in nonpaged area and Memory management BSOD on startup
2014-12-14T21:15:50+00:00
I have been getting crashes in the last month after the first program opens following startup. The error is most often PAGE_FAULT_IN_NONPAGED_AREA and sometimes MEMORY_MANAGEMENT. The issue usually does not happen twice in a row. That is, when the computer restarts after crashing, it normally runs smoothly until I shut it down again.
Running memtest for several hours came up clean. chkdsk did not appear to solve anything or reveal any problems. Windows is up to date.
Link to minidump files:
https://onedrive.live.com/redir?resid=D7F4A227A3E09142!112&authkey=!AOijjiTwDLK33ag&ithint=folder%2c
This custom built machine is approx 1.5 years old, problems began 1 month ago.
EDIT: Crashes just started during "normal" operation instead of simply on startup.
New minidump file:
https://onedrive.live.com/redir?resid=D7F4A227A3E09142!113&authkey=!AJTkM1bofGDZSYk&ithint=file%2czip
2015-01-02T05:56:35+00:00
Please run driver verifier (DV) per the instructions in the link below.
Note: Make sure to read and remember the steps to reset DV in the event of a crash, and post a link to the newly generated crash dump here.
Driver Verifier-- tracking down a mis-behaving driver. Created by ZigZag3143, Co.authored by by JMH3143
http://answers.microsoft.com/en-us/windows/wiki/windows_other-system/driver-verifier-tracking-down-a-mis-behaving/f5cb4faf-556b-4b6d-95b3-c48669e4c98
42 additional answers
    2015-01-12T22:04:30+00:00
    You are Welcome and thanks for the feedback.
    2015-01-12T19:39:03+00:00
    It's been 3 days and have had no issues. I'm going to mark this thread as solved.
    I can't thank you both enough for helping me do this. You saved me a great deal of time and possibly money. Thanks for sticking with me for this whole last month, it has been very informative.
    Downloaded BlueScreenView.
    Thanks to you I should be able to solve a variety of driver-related problems on my own.
