f you are still having problems I would replace the fan.
Also is your BIOS up to date?
J W Stuart: http://www.pagestart.com
First of all: I know that I have been having a problem with my HP Laptop Battery, and with its cooling Fan.
However, I am now wondering what detected this error below as long as it was shown even before the notification saying 'the press 'ESC' key for Start-up menu.' Thus, if the BIOS detected that there was a problem with the HP Battery storage', then this error should have been listed after 'press 'ESC' key for Start-up menu.' was passed.
'HP Battery Alert: The system has detected the storage capacity of the battery stated below to be very low. For optimal performance, this battery may need to be replaced.'
That alert lasted about 15 seconds, and then the 'press 'press 'ESC' key for Start-up menu.' is shown.
Next: This is error below showed me::
'The system didn't detect that a cooling fan is operating correctly'
I know that BIOS detected that a problem with 'Cooling Fan' since the Alert of error was shown after passing 'press 'ESC' key for Start-up menu.'
Any comments would be highly appreciated
Thanks a lot,
Yes, my BIOS is up to date even before cleaning the old fan. I was expecting that error was related to that BIOS is not up to date. So, I have updated it before dismantling my laptop to clean the old fan, and vent of heatsink.
If you are still having problems I would replace the fan.
I no longer have a new fan which can be compatible with my laptop, I have returned that new fan to the merchant. I have not used that new fan for two reasons, the first one I am NOT quite sure that that fan would be solve the problem with error 'the system has detected a cooling fan is not operating properly..', the other one is since it would be costing me a lot (about $50 for just a fan, in eBay.com, the Fan/heatsink assembly is sold for $30), so I have returned it to the merchant, although I have hardly found it in Yemen because HP Pavilion Notebooks parts are not sold in Yemen.
I have been still asking you about this utility to know if my fan is working well or not since the error 'The system has detected a cooling fan is not operating properly' appears to me again, after I have blown the old fan with a compressed air and cleaned it with a paint thinner. Also, even I have cleaned the exterior vents in the heatskin/metal plate with the paint thinner and with compressed air. I.e. While dismantling my computer, I thoroughly removed dust from all internal cooling components. Also, I ensured that wires from the system and CPU fans are connected to the motherboard securely.
Yes, the fan blows air out, and the air is fairly warm, but the air blown out by fan is not very quickely. The fan is blowing warm air from the computer.
Note: I only applied new thermal compound on both of only the tops of CPU and GPU. I didn't cover the entire tops of CPU and GPU with new thermal compound since I only found that the old thermal compound was only put on the tops of CPU and GPU. It is not put on the entire tops of CPU and GPU.
Furthermore**:** Could you please find another time convenient to you to reply to my points below:
Desktops do not have an integrated card on the motherboard, they are either integrated into the CPU like your laptop or the use the older style AGP or newer PCIe slots.
Secondly:
Could you please not ignore my points below?
I have Desktop Computer(Intel P 4, 512MB of RAM(DDR), and Graphics Card with 256MB of RAM)
My P 4 has a motherboardintegrated Graphics Card(onboard(Internal) VGA), Audio Card, and Network adapter. The motherboard manufacturer is Asrock(775i65G(REV: G/A 2.12) with integrated Graphics Card , and AGP slot to which a removable graphics card can be installed.
The amount of memory for the internal GPU is set in the BIOS.
**Thirdly:**There is no memory amount for the internal GPU set in the BIOS at all. There is only: Processor Type: Intel (R) Core(TM) i5-2410M. CPU@2.30GHz.
Fourthly: Why do you think that the internal Intel GPU is not stated in the spec of my notebook, only this 'Video Graphics:: AMD Radeon HD 6770M (1 GB DDR5)' is said in the spec.
Fifthly: Do you think that AMD Radeon HD6770 is the discrete GPU integrated into motherboard?
Intel, You must set the BIOS to disable the internal/Intel GPU and just use the HD6770.
Finally:(This is a little bit longer)
Although there is no option at all in my BIOS to set internal/Intel GPU to disable, I would like you to let me know:::
1- Why must I set that? If I had set that, then I could be no longer able to switch between graphics 'power-saving GPU, which is Intel GPU, and high-performance GPU, which is 'discrete GPU/HD6770.
2- I can switch between graphics (IGUP) and (DGPU) without seeing Switchable Graphics Mode in my BIOS
I am nearly sure that there is no option to set the Intel GPU to disable in my BIOS. I have tried that before(could you please take some time to look at my points below).
I can switch between two graphics 'Intel graphics and ATI Radeon Graphics', although the ' that option 'switchable graphics mode' found in the third screen shot below is not seen in my BIOS at all.
In this screen shot below, Intel graphics is only active.
In this screen shot below, ATI Radeon graphics is only active.
But I didn't find any striking difference between when integrated GPU is only active and when the Discrete (dGPU) is only active. Thus, why should I choose one other than the other?
What do I get?
As long as I can switch between two graphics without seeing this switchable graphics mode in my BIOS, I think that I don't need to update the BIOS to enable switchable graphics mode
Yes, I really couldn't find any option to 'Selecting a Switchable Graphics Method, Dynamic Scheme or Fixed Scheme. Is it because switchable graphics mode is not seen in my BIOS?
As discussed in the article, that switching between two graphics needs to update the BIOS until seeing Switchable Graphics Mode in BIOS. However, I have not updated the BIOS, but I can switch graphics (IGUP) and (DGPU) without seeing Switchable Graphics Mode in BIOS.
Besieds, I really have updated my BIOS from version: F.05 into F.1B, but the switachable Graphics mode in this screen shot above wasn't found at all. Also, there is no Intel Smart Tecnology in BIOS as it there in the screen shot above. I don't know why.
My GUPs are AMD Radeon and Intel graphics
Yes, apparently their are some motherboards with integrated graphics, Dell sold some P4 boards years ago. So you are correct, its just hat I have never seen any.
I guess your BIOS does not have this option.
Have no answer as to why it is included with the specifications, that most likely was a decision by the PC / Motherboard manufacture.
Yes it is.
I thought it would help keep the CPU running cooler.
a) If that works for you then stick with it.
b) Not all BIOS's include all possible settings, higher end motherboards usually have more options, entry level fewer option (based on the chipset and supported CPUs) and store bought system like Dell, HP, Acer the least number of settings the user has available and can change.
- My P 4 has a motherboardintegrated Graphics Card(onboard(Internal) VGA), Audio Card, and Network adapter. The motherboard manufacturer is Asrock(775i65G(REV: G/A 2.12) with integrated Graphics Card , and AGP slot to which a removable graphics card can be installed.
Thank you so much indeed,
So, as your previous comment '**Desktops do not have an integrated card on the motherboard, they are either integrated into the CPU like your laptop or the use the older style AGP or newer PCIe slots.'**was corrected by you now, I would return to my old questions you have ignored before.
I know A 'graphics card' is the subsystem inside the PC that handles the video output. Can be a stand-alone card, or integrated into the CPU.
So, my questions are:
**Firstly:**Then, the desktop computers are much better than notebook computers since I noticed that almost all desktop computers have a graphics card integrated into motherboard, and another AGP slot to which an external stand-alone graphics card can be installed.
So, in desktop computers, if the integrated graphics card got defective, I have another AGP slot to which I can install a stand-alone graphics card.
Also, if external graphics card was defective, then I can replace it without replacing the entire motherboard.
However, I noticed that laptops/notebooks(like mine) have a a discrete graphics card integrated into motherboard, and graphics card integrated into CPU, then if the discrete graphics card integrated to motherboard got defective, then I would need to replace the whole motherboard. If the graphics card integrated into CPU got defective, I would replace the CPU.
**Secondly: Could you please confirm this for me:**I noticed that there is a slight difference between desktop and notebooks.
In desktop computers, the internal graphics card is integrated into motherboard. However, in notebooks(like mine), the internal graphics card(called:internal GPU) is integrated into CPU.
However, In desktop computer, the external stand-alone graphics card is discrete which can be installed into the AGP slot/PCI express.
However, in notebooks(like mine), the discrete graphics card(called discrete GPU) is integrated into motherboard.
You think that my BIOS does not have this option of Switchable Graphics mode as well, although my motherboard is Hewlett-Packard? This is most strangE . My BIOS lacks many options, although BIOS vendor is insyde H20 AY44 7578, and its motherboard is Hewlett-Packard?
Note this screen shot was taken from an article of how to Switchable Graphics mode in BIOS at HP support website.
if that option set the BIOS to disable the internal/Intel GPU and just use the HD6770. were available on my BIOS, and If I set it, then then how can I switch between the 'power-saving GPU, and high-performance GPU?
When you said 'Intel, You must set the BIOS to disable the internal/Intel GPU and just use the HD6770., you meant that with to change Switchable Graphics mode to fixed? Or this is difference option other than this one which is below
By the way, you don't reply to me if cleaning the old fan with that paint thinner would not let the fan function again as it is supposed? I will need to replace the fan with a new one even if the physically outside form of the old fan is still fine and good.
As said before
Could you please reply to my final questions to end this problem?
