I'm working on it, will reply back tomorrow.
'Battery Alert' appears before the 'press 'ESC' key for Start-up menu.', however, ' Cooling Fan Alert' appears after 'press 'ESC' key for Start-up menu.'
First of all: I know that I have been having a problem with my HP Laptop Battery, and with its cooling Fan.
However, I am now wondering what detected this error below as long as it was shown even before the notification saying 'the press 'ESC' key for Start-up menu.' Thus, if the BIOS detected that there was a problem with the HP Battery storage', then this error should have been listed after 'press 'ESC' key for Start-up menu.' was passed.
'HP Battery Alert: The system has detected the storage capacity of the battery stated below to be very low. For optimal performance, this battery may need to be replaced.'
That alert lasted about 15 seconds, and then the 'press 'press 'ESC' key for Start-up menu.' is shown.
Next: This is error below showed me::
'The system didn't detect that a cooling fan is operating correctly'
I know that BIOS detected that a problem with 'Cooling Fan' since the Alert of error was shown after passing 'press 'ESC' key for Start-up menu.'
Any comments would be highly appreciated
2016-06-14T00:53:01+00:00 -
2016-06-14T18:35:37+00:00 Temperature-Related Frequently Asked Questions for Desktop and Mobile Intel® Processors
http://www.intel.com/content/www/us/en/support/processors/000005597.html
Your CPU temperatures are OK considering the load and you are not receiving any warning messages.
Your graphics is too hot, but that could be becasue you are running multiple streaming or you did not apply the thermal paste correctly. ZP-360 is not the best thermal compound to use which could also be a problem.
Try running a single steaming video and post back your results.
J W Stuart: http://www.pagestart.com
2016-06-15T04:39:40+00:00 Your graphics is too hot, but that could be becasue you are running multiple streaming or you did not apply the thermal paste correctly. ZP-360 is not the best thermal compound to use which could also be a problem.
I was NOT running many streaming videos. However, all what I was running four streaming videos.(two on Youtbue.com, and two videos saved on my HDD and palyed with my media player installed on my Windows
Now, this results below was taken while running one video saved on my HDD and palyed with my media player installed on my Windows, and two on Youtube via internet.
Could you please reply to my points below:
1- I have run the SpeedFan tool, and I have sent its test results to you before. Have you seen it? I do think it is just a fan speed-monitioring software, and it is not fan speed software?
2- Although I have sent the spare part number of my old fan/heat sink to the seller before purchasing the fan/heatsink that I need, unfortunately the new fan/ heat sink assembly purchased from eBay was not fitted to my motherbooard.(i.e. it wasn't mounted to the CPU and GPU). However, only the fan was similar to my old fan. So, I took out(removed) my old fan from my old heat sink, and after taking the new fan from my new heat sink, I installed the new fan in-place my old heat sink very well.
These are two faces for the old fan/heat sink:
These are two faces for the new fan/heat sink purchased from the eBay:
3- By the way, the new fan/heat sink NOT suitable to be in-place my old fan/heat sink has been pre-applied with thermal compound by vendor. So, all what I need to do is applying new thermal compound onto the CPU and GPU, and mounted Fna/heats sink onto the CPU and GPU. But do you think it is reasonable there is a pre-applied thermal compound on the new heat sink? If yes, then If I applied new thermal compound onto CPU and GPU, and in the heat sink, the contact surfaces to CPU and GPU are pre-applied with thermal compound by the vendor, then the amount of thermal compound would be much.
4- You told me to "open the Control Panel / Power options / Change plan settings / Change advanced power settings / Processor power management / and check the Minimum and Maximum power state settings."
But when I did, you didn't comment on it?
2016-06-15T15:07:20+00:00 I was NOT running many streaming videos. However, all what I was running four streaming videos.(two on Youtbue.com, and two videos saved on my HDD and palyed with my media player installed on my Windows
It is just monitoring software.
Yes, it is a common practice to have a pre-applied pad of thermal compound. However most pre-applied compound / pad is not as good as Thermal Grease/ paste.
If by this you mean remove the paste from the new heat sink (which as you said does not fit on your computer) and use it on your old heat sink, no it is not a good idea, don't do it. Your system appears to be fine as it is now.
But when I did, you didn't comment on it? I did not see what I was looking for, so I did not comment, sorry.
2016-06-18T04:19:09+00:00 Yes, it is a common practice to have a pre-applied pad of thermal compound. However most pre-applied compound / pad is not as good as Thermal Grease/ paste.
Thanks a lot,
Could you please reply to my points below?
1- Although the GPU and CPU temperatures are not high at all(screen shot below), I found out sometimes I have been encountering the error message below specifically when trying loading websites with Firefox browser. Even while the website loading with Firefox is not responding, this error below appears. And once this error disappears, then the website opens well.
"Display driver stopped responding and has recovered"
Yes, I have checked my HP manufacture web, and I didn't find any newer driver of GPU than my driver installed.
Also, Firefox has only Skype add-on added. Do you think this is the reason. But if so, I would be facing with Google Chrome and MS IE since this 'Skype add-on' added as well.
2- do you know why only the fan removed from the new fan/heat sink assembly was fitted to my old fan/heatsink?
3- From the screen shots below, do you think you can distinguish the difference between the old fan/heatsink and new fan/heatsink (why is the new fan/heat sink not fitted to the old one?).
Although I have sent the spare part number of my old fan/heat sink to the seller before purchasing the fan/heat sink that I need, unfortunately the new fan/ heat sink assembly purchased from eBay was not fitted to my motherboard.(i.e. it wasn't mounted to the CPU and GPU). However, only the fan was similar to my old fan. So, I took out(removed) my old fan from my old heat sink, and after taking the new fan from my new heat sink, I installed the new fan in-place my old heat sink very well.
4- As you said it is a common practice to have a pre-applied pad of thermal compound on the new heat sink. So, when I apply new Thermal Grease/paste onto the CPU and GPU surfaces, and mount the one heat sink to the CPU and GPU, then the mount of thermal compound would exceed the required limit.
