Zoom in on the photos from both suppliers
(Copy and paste both to a folder) and open / view each photo using Microsoft's Paint.exe and you can see it's a rubber pad.
First of all: I know that I have been having a problem with my HP Laptop Battery, and with its cooling Fan.
However, I am now wondering what detected this error below as long as it was shown even before the notification saying 'the press 'ESC' key for Start-up menu.' Thus, if the BIOS detected that there was a problem with the HP Battery storage', then this error should have been listed after 'press 'ESC' key for Start-up menu.' was passed.
'HP Battery Alert: The system has detected the storage capacity of the battery stated below to be very low. For optimal performance, this battery may need to be replaced.'
That alert lasted about 15 seconds, and then the 'press 'press 'ESC' key for Start-up menu.' is shown.
Next: This is error below showed me::
'The system didn't detect that a cooling fan is operating correctly'
I know that BIOS detected that a problem with 'Cooling Fan' since the Alert of error was shown after passing 'press 'ESC' key for Start-up menu.'
Any comments would be highly appreciated
Yes, it has. However, the first screen shot of the heatsink which is sold for $18.
However, other heatsinks having the same replace part number and sold for more than $26, such as the second screen shot, don't have the pad in clear view.
I don't think that the heatsink sold for $18 is better than others sold more than $26.
I have done
However, pad is still not clear.
3- What material do you use to clean the old fan? You use Isopropyl alcohol- 99%???
First I use #1 Coffee filter in my screen shot and apply a small amount of Isopropyl alcohol (#2) to the filter and use it to remove the old thermal paste from both the heat sink and CPU.
The I use #3 (Thermal Material Remover) and apply a small amount to another Coffee filter to remove any remaining thermal past from the CPU and heat sink.
Next I use #4 (Thermal Surface Purifier) and apply a small amount to another Coffee filter to prepare the CPU and heat sink. Then I apply the new thermal paste.
Items number 3 and 4 in my screen shot were purchased from Amazon, scroll down read the product description as posted on Amazon's web site:http://www.amazon.com/ArctiClean-60ml-Kit-30ml/dp/B0007TOR08/ref=sr_1_1?ie=UTF8&qid=1443896029&sr=8-1&keywords=Thermal+heatsink+cleaner
Thanks a lot,
First of all, I am very very upset that I live in a county out of commerce since I have been looking for fan heatsink, and other parts for my notebook for about a year. But they are not available in Yemen. I contact the HP support team in the closer country to me, which is United Arab Emirates. But they told me they cannot be able to help me by shipping the spare parts I need. Also, since not all sellers can ship to Yemen. Also, Items shipped to Yemen right now, even in fine conditions, get stolen or lost in the Yemen customs. I only would try to find a way or ask a seller at any online seller website if he/she can ship to a third party shipping address, such as Saudi Arabia. Then, I would use an shipping address of friend of mine residing in Saudi Arabia.
Could you please confirm my points below:
1- you used Isopropyl alcohol (#2), and Items number 3 and 4 only to remove the old thermal, do you think this is redundant, and a was a waste of money.
2- Coffee filter can only be used to do this action or it has other benefits/uses., if have other uses could you give me a link of a good kind of Coffee filter at amazon.com or eBay.com
3- Items number 3 and 4 and Isopropyl alcohol, all could only use to remove the old thermal compounds, or I can use them to clean the notebook screens. If no, then I would not always remove thermal compound(only one time I would do, so what I would do for the remains).
4- Could you please give me a link of a good kind of Isoproply alcohol at amazon.com or ebay.com
5- I know how to contact a seller at eBay.com by clicking on the seller's name shown under each item, however, I really don't find a way to contact a seller at Amazon.com since there is no sellers' names shown under items at Amazon.com.
6- I can find thermal compound brand you used at amazon.com or eBay.com as well?
7- could you please reply to this point below:
Yes, my fan has rubber pad(screen shot below is for my fan/heatsink)
However, the first screen shot of the heatsink posted before is sold for $18.
However, other heatsinks having the same replace part numbers, such as the second screen shot posted before is sold for more than $26, such as the second screen don't have the pad in clear view.
I have done
No as item 3 and 4 are very costly, so I remove as much of the old thermal paste as possible. Then I use items 3 and 4 to remove what may be nearly invisible to my or your eyes the very thin film that may still be on the surface.
Do not use items 2, 3, or 4 to clean the screen, may damage the surface !
Most items on Amazon are sold or fulfilled directly by Amazon.
I have done
Can you reuse your rubber pad if the one you purchase does not come with the pad?
Thanks a lot,
Note, I have not yet purchased any of these products.
I understand from your speech, that all these products:
Isopropyl alcohol (#2), and Items number 3 and 4 and coffee filter are used to clean the old thermal compound(remains). There are no other benefits/users for them.
I only would use to remove old thermal compound for one time. So, there too much of product(material) of each product above will be left. So, where can I use it ?
However, other heatsinks having the same replace part numbers, such as the second screen shot posted before is sold for more than **$26,**such as the second screen don't have the pad in clear view.
I have done
I have not yet purchased any fan/heatsink at all, but I only copied those images for heatsink from amazon.com and eBay.com. The one sold for $18 has a clear rubber pad image. However, all the others more expensive don't have.
And as you saidI don't think that the heatsink sold for $18 is better than others sold more than $26.
