There is nothing to see in your screen shots except the high core / System temperature as shown in Red.
Rubbing Alcohol is another name. I have no idea where you can find it in your country, ask a Doctor.
Cleaning the old compound by applying new compound will not work, you need to remove "ALL" the old compound leaving a thoroughly clean surface on which you can apply the new compound.
Thanks a lot,
1- why have you considered nothing to be seen in my screen shots except the high core temperature? Are the screen shots not clear?
2- As YOU SAID before: Their is heat sensor is built into the CPU and sometimes an external sensor that is part of the motherboard. The heat sensor is used to measure the heat being generated by the CPU, if the sensor detects too much heat it will result in either reduced processor clock speed, controlled by software installed by the PC manufacture and or the BIOS shutting down the computer down.
YOU SAID that if sensor heat is defective, then I will need to either replace motherboard or CPU according to :: Yes, check your CPU and motherboard specifications to see which or both.
I didn't find any specifications letting me understand whether I will need to replace CPU or motherboard if sensor heat got defective. ALL what I have is below, and those screen shots:
What do you want me to see in my motherboard/CPU specifications? I only have general specs of my PC. There is no information about motherboard in my general Specs of my PC.
Product Name: dv6-6093ex
Product Number:LM610EA
Microprocessor: 2.3 GHz Intel Core i5-2410M
Microprocessor: Cache3 MB L3 cache
Memory: 6 GB DDR3
Memory Max Upgradeable to 8 GB DDR3
Video Graphics: AMD Radeon HD 6770M (1 GB DDR5)
Display: 39,6 cm (15,6") High-Definition LED HP BrightView Display (1366 x 768)
Hard Drive: 750 GB SATA (5400 rpm)
Multimedia DriveLightScribe SuperMulti DVD±R/RW with Double Layer Support
Network Card: Integrated 10/100/1000 Gigabit Ethernet LANHP Customer Support
As a result, I think if I give you these screen shots of my motherboard and CPU taken by Specy program , you can tell me which specifications you want me to check to know if I would want to replace the motherboard or CPU if heat sensor was faulty???????.
3- why should I have to ask a doctor about Alcohol? Is it a medical solution?
4- while removing the old compound, I found it was wet like wet mud. So I can even remove it with my hand.
