Edge Frozen with Virus Warning Popup
2015-08-10T20:42:30+00:00
After navigating to a web page, a popup hijacked the Edge browser.
The popup is a false virus warning, with audio, that repeats endlessly.
I used Task Manager to close Edge browser, but after re-opening, it returns to the hijacked page.  There is no time to open another tab, or reach settings.  How can this be cleared.
First I tried searching for /user/appdata for Edge entries, and only found a couple, deleted them, but no effect.
I launched msconfig, and set to boot to Safe Mode, minimal.  I tried launching Edge in Safe, but you get a warning saying Edge will not launch using the built in administrator account. IE still ran, but no network (as you might expect).  I cleared history in IE.  But then was unable to relaunch msconfig!  Pressing Start flashed a start menu but it disappeared. Selecting the search box wound not search.  I ended up launching Control Panel using win+x, and finding System Configuration that way.
When I returned to normal Windows, Edge was set back to its home page.
Clearly this is not a good work around. I can't imagine explaining it to my little niece or grandmother.
Please suggest something more rational.
[Moved from Windows]
2015-08-13T17:59:55+00:00
When this happened to me, I closed Microsoft Edge using the Task Manager.
Then in the search bar next to the Windows 10 logo on the bottom off the screen (I call it the "Cortana Search"), I typed in google.com and hit enter.
Microsoft Edge opened up with a new tab for Google.  You can see the offending site still opens in a tab that doesn't have focus.  Click the "X" to close Edge. Do not click on the offending site tab or it will get focus again.
When Edge closes nicely, I won't "Restore" the sessions and the offending site tab will be gone.
2017-04-25T22:28:31+00:00
This did not work. It closed the offending page, but when I re-opened Edge it popped back up again.
It's a common scam. Click the OK button at the bottom of the popup. You should then see a box Do not allow this site to create new messages. Check it and then close the window.
If that doesn't work, for Edge, follow the instructions by Scott_Ki here:
https://answers.microsoft.com/en-us/protect/forum/protect_other-protect_scanning/edge-frozen-with-virus-warning-popup/7212a393-90ad-48d0-ab55-4ffe1f21a554?page=2&msgId=7618ae67-bf16-4155-bf90-d8a7405ee199
For all other browsers, use the Task Manager to exit the browser. Reboot and see if the pop-up goes away.
How to Use the New Task Manager.
http://www.wikihow.com/Open-Windows-Task-Manager
If the problem persists, for any browser:
Remove Tech Support Scam pop-up (Call For Support Scam)
http://malwaretips.com/blogs/remove-tech-support-scam-popups/
Please read:
PSA: Tech Support Scams Pop-Ups on the Rise
https://blog.malwarebytes.org/fraud-scam/2014/11/psa-tech-support-scams-pop-ups-on-the-rise/
Breaking down a notably sophisticated tech support scam M.O.
https://blogs.technet.microsoft.com/mmpc/2017/03/02/breaking-down-a-notably-sophisticated-tech-support-scam-m-o/
For more information, see this post by GreginMich
https://answers.microsoft.com/en-us/protect/forum/protect_other-protect_scanning/1-888-2361-scam/0990122e-61a9-431b-947e-a904c202fa7c?msgId=8d26f1a8-041a-4351-9c24-a222fb305cbd
195 additional answers
    2015-08-26T20:25:37+00:00
    And, of course, the problem couldn't possibly be down to users choosing to visit high-risk/suspect websites?
    2015-08-26T21:39:44+00:00
    @Erdeslawe
    No. In this case it seems to be a Edge bug.
    See my reply to you here: https://answers.microsoft.com/en-us/windows/forum/windows_10-networking/microsoft-edge-browserror/ca3eb795-484d-4c2a-8331-7d2e35d7fd05?page=2&msgId=c8f450f7-2e66-4f1c-a8dc-02862482d4ab
    In the same thread I also posted about another solution which works:
    User RenePeerboom shared the following solution:
    1. Open Edge (internet) indirectly, that is from say an email link as an example. Then at the top tabs, the first one is the offending one, DO NOT OPEN IT, just delete it by clicking on the X at the right of that tab, while you have the screen of the site you were able to access indirectly on.
    2. Now go to the EDGE settings, top right corner of screen, click on the three ... which stand for "more" there on the sub-menus click on Settings and clear the browser data.
    3. Close Edge and re-open; the offending site should be gone. It worked for me.
    From <http://answers.microsoft.com/en-us/protect/forum/protect\_other-protect\_scanning/how-to-remove-softwareupdateproductcom-from/ad19b030-e2f5-43de-ae5b-70bf8b24fa2e>
    2015-08-27T16:15:44+00:00
    Hi fellow windows sufferers,used the ctrl+w and hey presto warning gone ,thanks so much for your help,Cheers.
