Edge Frozen with Virus Warning Popup
2015-08-10T20:42:30+00:00
After navigating to a web page, a popup hijacked the Edge browser.
The popup is a false virus warning, with audio, that repeats endlessly.
I used Task Manager to close Edge browser, but after re-opening, it returns to the hijacked page.  There is no time to open another tab, or reach settings.  How can this be cleared.
First I tried searching for /user/appdata for Edge entries, and only found a couple, deleted them, but no effect.
I launched msconfig, and set to boot to Safe Mode, minimal.  I tried launching Edge in Safe, but you get a warning saying Edge will not launch using the built in administrator account. IE still ran, but no network (as you might expect).  I cleared history in IE.  But then was unable to relaunch msconfig!  Pressing Start flashed a start menu but it disappeared. Selecting the search box wound not search.  I ended up launching Control Panel using win+x, and finding System Configuration that way.
When I returned to normal Windows, Edge was set back to its home page.
Clearly this is not a good work around. I can't imagine explaining it to my little niece or grandmother.
Please suggest something more rational.
[Moved from Windows]
2015-08-13T17:59:55+00:00
When this happened to me, I closed Microsoft Edge using the Task Manager.
Then in the search bar next to the Windows 10 logo on the bottom off the screen (I call it the "Cortana Search"), I typed in google.com and hit enter.
Microsoft Edge opened up with a new tab for Google.  You can see the offending site still opens in a tab that doesn't have focus.  Click the "X" to close Edge. Do not click on the offending site tab or it will get focus again.
When Edge closes nicely, I won't "Restore" the sessions and the offending site tab will be gone.
2017-04-25T22:28:31+00:00
This did not work. It closed the offending page, but when I re-opened Edge it popped back up again.
It's a common scam. Click the OK button at the bottom of the popup. You should then see a box Do not allow this site to create new messages. Check it and then close the window.
If that doesn't work, for Edge, follow the instructions by Scott_Ki here:
https://answers.microsoft.com/en-us/protect/forum/protect_other-protect_scanning/edge-frozen-with-virus-warning-popup/7212a393-90ad-48d0-ab55-4ffe1f21a554?page=2&msgId=7618ae67-bf16-4155-bf90-d8a7405ee199
For all other browsers, use the Task Manager to exit the browser. Reboot and see if the pop-up goes away.
How to Use the New Task Manager.
http://www.wikihow.com/Open-Windows-Task-Manager
If the problem persists, for any browser:
Remove Tech Support Scam pop-up (Call For Support Scam)
http://malwaretips.com/blogs/remove-tech-support-scam-popups/
Please read:
PSA: Tech Support Scams Pop-Ups on the Rise
https://blog.malwarebytes.org/fraud-scam/2014/11/psa-tech-support-scams-pop-ups-on-the-rise/
Breaking down a notably sophisticated tech support scam M.O.
https://blogs.technet.microsoft.com/mmpc/2017/03/02/breaking-down-a-notably-sophisticated-tech-support-scam-m-o/
For more information, see this post by GreginMich
https://answers.microsoft.com/en-us/protect/forum/protect_other-protect_scanning/1-888-2361-scam/0990122e-61a9-431b-947e-a904c202fa7c?msgId=8d26f1a8-041a-4351-9c24-a222fb305cbd
195 additional answers
    2016-09-22T20:55:56+00:00
    I fell for this scam last year. The noise was awful & I thought I had to call the "Microsoft" number listed. Obviously I'm not very tech savvy, so when the person on the phone could make the noise stop & free my web browser I bought their "anti-virus" software. It was very weird how he could control my computer remotely.
    My husband later informed me it was a scam, we blocked my credit card payment & took my laptop to Geek squad to be rebooted.
    Then today the same thing happened. Luckily I had my phone to find this group online.
    So what worked for me to fix this was to launch "Windows store gift card promo", but I think anything that opens another web tab will work. I cleared all the web history. Shut the app down. Relaunched & it's normal.
    Hppe this helps. Good luck
    2016-09-24T16:14:50+00:00
    My wife hit a link from a Facebook post, something about a soldier teaching somebody a lesson?  This "Virus warning popped up from Windows 10 Edge, but Windows Defender and msert scans using the maximum scan settings, found nothing.  I'll clear her cache when I finish my cigar and go back in the house.  I didn't see where anyone else had posted a picture of this version, but I did NOT read every post so...  This one had a mouse moving about the screen and text scrolling in the background.
    It reminded me of a page I had on my web site that "appeared" to open a dos box and run a del /s on c:, automatically respond to the "are you sure" question with a "Y" for yes and then it would start scrolling through a ton of file names, "appearing" to wipe your files from c:.  Then it would "appear" to start a Mac OS install.  It amused some friends, scared the daylights out of others.  I added a "NOT REALLY" line to the end of it, but it took a few minutes to run and a few people would not wait that long so I took the page down to avoid causing them problems. o.O
    Now to block errorx3940e.ml until they come from the next one...
    2016-09-24T16:21:56+00:00
    Use the Task Manager to exit the browser. Reboot and see if the pop-up goes away.
      How to Use the New Task Manager in Windows 8 or 10
    http://www.howtogeek.com/108742/how-to-use-the-new-task-manager-in-windows-8/
      How to Use the Task Manager in Windows 7
    http://windows.microsoft.com/en-us/windows/end-process#1TC=windows-7
      [http://malwaretips.com/blogs/remove-tech-support-scam-popups/](http://malwaretips.com/blogs/remove-tech-support-scam-popups/)
      And see:
      See this post by GreginMich
    http://answers.microsoft.com/en-us/protect/forum/protect_other-protect_scanning/1-888-2361-scam/0990122e-61a9-431b-947e-a904c202fa7c#LastReply
