Edge Frozen with Virus Warning Popup
2015-08-10T20:42:30+00:00
After navigating to a web page, a popup hijacked the Edge browser.
The popup is a false virus warning, with audio, that repeats endlessly.
I used Task Manager to close Edge browser, but after re-opening, it returns to the hijacked page.  There is no time to open another tab, or reach settings.  How can this be cleared.
First I tried searching for /user/appdata for Edge entries, and only found a couple, deleted them, but no effect.
I launched msconfig, and set to boot to Safe Mode, minimal.  I tried launching Edge in Safe, but you get a warning saying Edge will not launch using the built in administrator account. IE still ran, but no network (as you might expect).  I cleared history in IE.  But then was unable to relaunch msconfig!  Pressing Start flashed a start menu but it disappeared. Selecting the search box wound not search.  I ended up launching Control Panel using win+x, and finding System Configuration that way.
When I returned to normal Windows, Edge was set back to its home page.
Clearly this is not a good work around. I can't imagine explaining it to my little niece or grandmother.
Please suggest something more rational.
[Moved from Windows]
2015-08-13T17:59:55+00:00
When this happened to me, I closed Microsoft Edge using the Task Manager.
Then in the search bar next to the Windows 10 logo on the bottom off the screen (I call it the "Cortana Search"), I typed in google.com and hit enter.
Microsoft Edge opened up with a new tab for Google.  You can see the offending site still opens in a tab that doesn't have focus.  Click the "X" to close Edge. Do not click on the offending site tab or it will get focus again.
When Edge closes nicely, I won't "Restore" the sessions and the offending site tab will be gone.
2017-04-25T22:28:31+00:00
This did not work. It closed the offending page, but when I re-opened Edge it popped back up again.
It's a common scam. Click the OK button at the bottom of the popup. You should then see a box Do not allow this site to create new messages. Check it and then close the window.
If that doesn't work, for Edge, follow the instructions by Scott_Ki here:
https://answers.microsoft.com/en-us/protect/forum/protect_other-protect_scanning/edge-frozen-with-virus-warning-popup/7212a393-90ad-48d0-ab55-4ffe1f21a554?page=2&msgId=7618ae67-bf16-4155-bf90-d8a7405ee199
For all other browsers, use the Task Manager to exit the browser. Reboot and see if the pop-up goes away.
How to Use the New Task Manager.
http://www.wikihow.com/Open-Windows-Task-Manager
If the problem persists, for any browser:
Remove Tech Support Scam pop-up (Call For Support Scam)
http://malwaretips.com/blogs/remove-tech-support-scam-popups/
Please read:
PSA: Tech Support Scams Pop-Ups on the Rise
https://blog.malwarebytes.org/fraud-scam/2014/11/psa-tech-support-scams-pop-ups-on-the-rise/
Breaking down a notably sophisticated tech support scam M.O.
https://blogs.technet.microsoft.com/mmpc/2017/03/02/breaking-down-a-notably-sophisticated-tech-support-scam-m-o/
For more information, see this post by GreginMich
https://answers.microsoft.com/en-us/protect/forum/protect_other-protect_scanning/1-888-2361-scam/0990122e-61a9-431b-947e-a904c202fa7c?msgId=8d26f1a8-041a-4351-9c24-a222fb305cbd
195 additional answers
  1. bhringer-9380 4,350 Reputation points Volunteer Moderator
    2016-04-03T01:03:36+00:00
    Here's a link for Edge Changelog which describes "Dialog Loop Protection for Microsoft Edge"
    New Microsoft Edge features (scroll down for 10240 Changelog)
    https://developer.microsoft.com/en-us/microsoft-edge/platform/changelog/desktop/10586/?compareWith=10240
    There's a new third-party tool for Edge Reset that maybe useful. Although I haven't tested (didn't want to tempt fate on new install of build 14295 and don't  have an earlier build) there is a least one issue that suggests it may not be suitable for the average user; it has options for malware scanning and speeding up computer which involves downloading other products from the same vendor which I suspect may not be in t he user's best interest and likely not necessary.
    Edge Reset Button 1.0
    http://www.majorgeeks.com/files/details/edge_reset_button.html
    ~bhringer
    2016-04-03T02:56:54+00:00
    Rational Approach:
    1.  Right click any *.html file on your hard drive and choose OPEN WITH from the drop down.  Choose OPEN WITH EDGE.  The file will open, and you'll see the tab for the noxious loop site.  Close the tab.  Done.
    Just want to thank you for that easy fix.  I, too, tried all the previous methods -- thinking it was definitely a virus and/or malware and not a pop-up.  I was ready to install McAffe anti-virus -- until I read your post.  Still, Microsoft should have foreseen this issue before they officially released Windows 10.  ;-)
    No. 1
    This work for me.
    Thanks a lot.
    Romy0427
    2016-04-04T17:09:32+00:00
    "The questions now are whether people will be willing to click on the OK button in order to gain access to the loop-breaking checkbox".....
    This is not a fix in this day and age of being told not to click on any link one is suspicious of.
    "also whether the original fix will be able to withstand the avalanche of rapidly-evolving dialog loop variants." ....
    At this time, it seems it hasn't.  I suspect they will keep on working on it though.  In the meantime, I am still a proponent of ending the program via task manager and restarting from  another html link or shortcut.
