Edge Frozen with Virus Warning Popup
2015-08-10T20:42:30+00:00
After navigating to a web page, a popup hijacked the Edge browser.
The popup is a false virus warning, with audio, that repeats endlessly.
I used Task Manager to close Edge browser, but after re-opening, it returns to the hijacked page.  There is no time to open another tab, or reach settings.  How can this be cleared.
First I tried searching for /user/appdata for Edge entries, and only found a couple, deleted them, but no effect.
I launched msconfig, and set to boot to Safe Mode, minimal.  I tried launching Edge in Safe, but you get a warning saying Edge will not launch using the built in administrator account. IE still ran, but no network (as you might expect).  I cleared history in IE.  But then was unable to relaunch msconfig!  Pressing Start flashed a start menu but it disappeared. Selecting the search box wound not search.  I ended up launching Control Panel using win+x, and finding System Configuration that way.
When I returned to normal Windows, Edge was set back to its home page.
Clearly this is not a good work around. I can't imagine explaining it to my little niece or grandmother.
Please suggest something more rational.
[Moved from Windows]
2015-08-13T17:59:55+00:00
When this happened to me, I closed Microsoft Edge using the Task Manager.
Then in the search bar next to the Windows 10 logo on the bottom off the screen (I call it the "Cortana Search"), I typed in google.com and hit enter.
Microsoft Edge opened up with a new tab for Google.  You can see the offending site still opens in a tab that doesn't have focus.  Click the "X" to close Edge. Do not click on the offending site tab or it will get focus again.
When Edge closes nicely, I won't "Restore" the sessions and the offending site tab will be gone.
2017-04-25T22:28:31+00:00
This did not work. It closed the offending page, but when I re-opened Edge it popped back up again.
It's a common scam. Click the OK button at the bottom of the popup. You should then see a box Do not allow this site to create new messages. Check it and then close the window.
If that doesn't work, for Edge, follow the instructions by Scott_Ki here:
https://answers.microsoft.com/en-us/protect/forum/protect_other-protect_scanning/edge-frozen-with-virus-warning-popup/7212a393-90ad-48d0-ab55-4ffe1f21a554?page=2&msgId=7618ae67-bf16-4155-bf90-d8a7405ee199
For all other browsers, use the Task Manager to exit the browser. Reboot and see if the pop-up goes away.
How to Use the New Task Manager.
http://www.wikihow.com/Open-Windows-Task-Manager
If the problem persists, for any browser:
Remove Tech Support Scam pop-up (Call For Support Scam)
http://malwaretips.com/blogs/remove-tech-support-scam-popups/
Please read:
PSA: Tech Support Scams Pop-Ups on the Rise
https://blog.malwarebytes.org/fraud-scam/2014/11/psa-tech-support-scams-pop-ups-on-the-rise/
Breaking down a notably sophisticated tech support scam M.O.
https://blogs.technet.microsoft.com/mmpc/2017/03/02/breaking-down-a-notably-sophisticated-tech-support-scam-m-o/
For more information, see this post by GreginMich
https://answers.microsoft.com/en-us/protect/forum/protect_other-protect_scanning/1-888-2361-scam/0990122e-61a9-431b-947e-a904c202fa7c?msgId=8d26f1a8-041a-4351-9c24-a222fb305cbd
195 additional answers
    2015-08-31T20:50:08+00:00
    run cc cleaner check all boxes except passwords and empty space cleaner.  Then run edge and go to known good tab, close all other tabs . worked for me. cc cleaner is a free down load just down lode and copy download from another computer if you can't get online,
    2015-09-02T17:55:06+00:00
    Try not to panic Mark,
    I don't think it is a huge issue.  Edge is slated to support 'extensions' in October, which will likely give it capabilities such as 'ad blocker' and a ton of other nice ones.
    I managed to clear the error, but it was not very simple.  Use IE as a backup, and lets see what they come up with.  Have a little faith.
    Just restore system in old time and problem gone.
  3. Virginia M 41,885 Reputation points Independent Advisor
    2015-09-02T18:45:47+00:00
    CCleaner will clean Edge browser of cookies etc, it may be worth a try for future reference.
