Windows 7 Ultimate 64 bit - Help with BSOD!!
2015-04-08T03:48:26+00:00
Hi All,
I am getting recurring BSOD errors on my Desktop. There are no recent hardware / software changes / additions other than windows updates.
Please help me with this.
OS: Windows 7 Ultimate 64bit - 8GB DDR3 RAM (with all latest Microsoft updates installed)
Motherboard and Processor - i7-870 processor on Intel DP55KG Motherboard
Dump File         : 040815-21590-01.dmp
Crash Time        : 4/8/2015 6:48:51 AM
Bug Check String  : BAD_POOL_HEADER
Bug Check Code    : 0x00000019
Parameter 1       : 00000000`00000003
Parameter 2       : fffffa80`0608fe20
Parameter 3       : fffffa80`0608fe20
Parameter 4       : 00000000`00000000
Caused By Driver  : ntoskrnl.exe
Caused By Address : ntoskrnl.exe+74ec0
File Description  : NT Kernel & System
Product Name      : Microsoft® Windows® Operating System
Company           : Microsoft Corporation
File Version      : 6.1.7601.18741 (win7sp1_gdr.150202-1526)
Processor         : x64
Crash Address     : ntoskrnl.exe+74ec0
Stack Address 1   :
Stack Address 2   :
Stack Address 3   :
Computer Name     :
Full Path         : C:\Windows\Minidump\040815-21590-01.dmp
Processors Count  : 8
Major Version     : 15
Minor Version     : 7601
Dump File Size    : 315,872
Dump File Time    : 4/8/2015 6:51:06 AM
Dump File         : 040815-24601-01.dmp
Crash Time        : 4/8/2015 2:36:33 AM
Bug Check String  : IRQL_NOT_LESS_OR_EQUAL
Bug Check Code    : 0x0000000a
Parameter 1       : ffffffff`ffffffd8
Parameter 2       : 00000000`00000002
Parameter 3       : 00000000`00000000
Parameter 4       : fffff800`0368924b
Processor         : x64
Stack Address 1   :
Stack Address 2   :
Stack Address 3   :
Computer Name     :
Full Path         : C:\Windows\Minidump\040815-24601-01.dmp
Major Version     : 15
Dump File Size    : 352,224
Dump File Time    : 4/8/2015 2:38:12 AM
Dump File         : 040115-21481-01.dmp
Crash Time        : 4/1/2015 8:08:42 PM
Bug Check String  : DRIVER_POWER_STATE_FAILURE
Bug Check Code    : 0x0000009f
Parameter 2       : fffffa80`06b03a10
Parameter 3       : fffff800`00b9a518
Parameter 4       : fffffa80`0694f0b0
Processor         : x64
Stack Address 1   :
Stack Address 2   :
Stack Address 3   :
Computer Name     :
Full Path         : C:\Windows\Minidump\040115-21481-01.dmp
Major Version     : 15
Dump File Size    : 1,001,424
Dump File Time    : 4/1/2015 9:27:00 PM
Dump File         : 033115-18891-01.dmp
Crash Time        : 3/31/2015 9:33:53 AM
Parameter 2       : fffffa80`06b0c060
Parameter 4       : fffffa80`0ba684f0
Processor         : x64
Stack Address 1   :
Stack Address 2   :
Stack Address 3   :
Computer Name     :
Full Path         : C:\Windows\Minidump\033115-18891-01.dmp
Major Version     : 15
Dump File Size    : 958,704
Dump File Time    : 3/31/2015 2:14:05 PM
Thank you,
Venu
2015-04-08T14:50:35+00:00
Were you running the Microsoft Safety scanner, when this occurred? Please run driver verifier (DV) per the instructions in the link below.
Note: Make sure to read and remember the steps to reset DV in the event of a crash, and post a link to the newly generated crash dump here.
Driver Verifier-- tracking down a mis-behaving driver. Co-Authored by ZigZag3143& JMH3143
http://answers.microsoft.com/en-us/windows/wiki/windows\_other-system/driver-verifier-tracking-down-a-mis-behaving/f5cb4faf-556b-4b6d-95b3-c48669e4c983
42 additional answers
    2015-05-05T12:17:26+00:00
    Do you still have driver agent installed, and if so, when was it installed and have you used it to search for and install your device drivers?
    Please uninstall it if it is still installed.
    2015-05-13T19:21:03+00:00
    Hi XP Rocks and Gerry,
    Sorry for the delay in responding.
    I am not using the driver agent now. I have uninstalled it.
    I am still getting the BSOD errors. The latest mini dump files are loaded on onedrive - http://1drv.ms/1F7VO5m
    Dump File         : 051315-140744-01.dmp
    Crash Time        : 5/13/2015 8:08:34 PM
    Bug Check Code    : 0x1000009f
    Parameter 1       : 00000000`00000004
    Parameter 2       : 00000000`00000258
    Parameter 3       : fffffa80`06114040
    Parameter 4       : fffff800`04c85510
    Caused By Address : ntoskrnl.exe+770aa
    File Version      : 6.1.7601.18839 (win7sp1_gdr.150427-0707)
    Processor         : x64
    Crash Address     : ntoskrnl.exe+770aa
    Stack Address 1   :
    Stack Address 2   :
    Stack Address 3   :
    Computer Name     :
    Full Path         : C:\Windows\Minidump\051315-140744-01.dmp
    Major Version     : 15
    Dump File Size    : 551,424
    Dump File Time    : 5/13/2015 8:13:41 PM
    Dump File         : 051315-24538-01.dmp
    Crash Time        : 5/13/2015 12:31:29 PM
    Parameter 1       : 00000000`00000020
    Parameter 2       : fffff8a0`0300da20
    Parameter 3       : fffff8a0`0300dff0
    Parameter 4       : 00000000`055d0115
    Caused By Driver  : Ntfs.sys
    Caused By Address : Ntfs.sys+8af33
    File Description  : NT File System Driver
    File Version      : 6.1.7600.16385 (win7_rtm.090713-1255)
    Processor         : x64
    Crash Address     : ntoskrnl.exe+748c0
    Stack Address 1   :
    Stack Address 2   :
    Stack Address 3   :
    Computer Name     :
    Full Path         : C:\Windows\Minidump\051315-24538-01.dmp
    Major Version     : 15
    Dump File Size    : 333,408
    Dump File Time    : 5/13/2015 12:32:35 PM
    Dump File         : 051215-26878-01.dmp
    Crash Time        : 5/12/2015 7:01:21 PM
    Bug Check String  : PAGE_FAULT_IN_NONPAGED_AREA
    Bug Check Code    : 0x00000050
    Parameter 1       : fffff901`302c54c1
    Parameter 2       : 00000000`00000000
    Parameter 3       : fffff960`000b58c8
    Parameter 4       : 00000000`00000005
    Caused By Driver  : win32k.sys
    Caused By Address : win32k.sys+231d10
    File Description  : Multi-User Win32 Driver
    Processor         : x64
    Crash Address     : ntoskrnl.exe+72a40
    Stack Address 1   :
    Stack Address 2   :
    Stack Address 3   :
    Computer Name     :
    Full Path         : C:\Windows\Minidump\051215-26878-01.dmp
    Major Version     : 15
    Dump File Size    : 304,568
    Dump File Time    : 5/12/2015 7:03:16 PM
    2015-05-13T22:04:21+00:00
    BAD_POOL_HEADER (19)
    The pool is already corrupt at the time of the current request.
    This may or may not be due to the caller.
    The internal pool links must be walked to figure out a possible cause of
    the problem, and then special pool applied to the suspect tags or the driver
    verifier to a suspect driver.
    Arguments:
    Arg1: 0000000000000020, a pool block header size is corrupt.
    Arg2: fffff8a00300da20, The pool entry we were looking for within the page.
    Arg3: fffff8a00300dff0, The next pool entry.
    Arg4: 00000000055d0115, (reserved)
    Please run DV, again and please upload and share a link to the generated file, this time.
    2015-05-14T08:39:11+00:00
    Hi XP Rocks,
    I ran DV and it crashed twice.
    The minidump is posted on onedrive. http://1drv.ms/1EFLfEv
    Dump File         : 051415-31949-01.dmp
    Crash Time        : 5/14/2015 11:51:56 AM
    Bug Check String  : PAGE_FAULT_IN_FREED_SPECIAL_POOL
    Bug Check Code    : 0x000000cc
    Parameter 1       : fffff980`4e8ceb82
    Parameter 3       : fffff800`03b70d8f
    Caused By Address : ntoskrnl.exe+748c0
    Processor         : x64
    Stack Address 1   :
    Stack Address 2   :
    Stack Address 3   :
    Computer Name     :
    Full Path         : C:\Windows\Minidump\051415-31949-01.dmp
    Major Version     : 15
    Dump File Size    : 262,144
    Dump File Time    : 5/14/2015 1:45:35 PM
    Dump File         : 051415-238993-01.dmp
    Crash Time        : 5/14/2015 11:42:29 AM
    Parameter 1       : fffff980`26638b82
    Parameter 3       : fffff800`03b83d8f
    Processor         : x64
    Stack Address 1   :
    Stack Address 2   :
    Stack Address 3   :
    Computer Name     :
    Full Path         : C:\Windows\Minidump\051415-238993-01.dmp
    Major Version     : 15
    Dump File Time    : 5/14/2015 11:47:46 AM
