Windows 7 Ultimate 64 bit - Help with BSOD!!
2015-04-08T03:48:26+00:00
Hi All,
I am getting recurring BSOD errors on my Desktop. There are no recent hardware / software changes / additions other than windows updates.
Please help me with this.
OS: Windows 7 Ultimate 64bit - 8GB DDR3 RAM (with all latest Microsoft updates installed)
Motherboard and Processor - i7-870 processor on Intel DP55KG Motherboard
Dump File         : 040815-21590-01.dmp
Crash Time        : 4/8/2015 6:48:51 AM
Bug Check String  : BAD_POOL_HEADER
Bug Check Code    : 0x00000019
Parameter 1       : 00000000`00000003
Parameter 2       : fffffa80`0608fe20
Parameter 3       : fffffa80`0608fe20
Parameter 4       : 00000000`00000000
Caused By Driver  : ntoskrnl.exe
Caused By Address : ntoskrnl.exe+74ec0
File Description  : NT Kernel & System
Product Name      : Microsoft® Windows® Operating System
Company           : Microsoft Corporation
File Version      : 6.1.7601.18741 (win7sp1_gdr.150202-1526)
Processor         : x64
Crash Address     : ntoskrnl.exe+74ec0
Stack Address 1   :
Stack Address 2   :
Stack Address 3   :
Computer Name     :
Full Path         : C:\Windows\Minidump\040815-21590-01.dmp
Processors Count  : 8
Major Version     : 15
Minor Version     : 7601
Dump File Size    : 315,872
Dump File Time    : 4/8/2015 6:51:06 AM
Dump File         : 040815-24601-01.dmp
Crash Time        : 4/8/2015 2:36:33 AM
Bug Check String  : IRQL_NOT_LESS_OR_EQUAL
Bug Check Code    : 0x0000000a
Parameter 1       : ffffffff`ffffffd8
Parameter 2       : 00000000`00000002
Parameter 3       : 00000000`00000000
Parameter 4       : fffff800`0368924b
Processor         : x64
Stack Address 1   :
Stack Address 2   :
Stack Address 3   :
Computer Name     :
Full Path         : C:\Windows\Minidump\040815-24601-01.dmp
Major Version     : 15
Dump File Size    : 352,224
Dump File Time    : 4/8/2015 2:38:12 AM
Dump File         : 040115-21481-01.dmp
Crash Time        : 4/1/2015 8:08:42 PM
Bug Check String  : DRIVER_POWER_STATE_FAILURE
Bug Check Code    : 0x0000009f
Parameter 2       : fffffa80`06b03a10
Parameter 3       : fffff800`00b9a518
Parameter 4       : fffffa80`0694f0b0
Processor         : x64
Stack Address 1   :
Stack Address 2   :
Stack Address 3   :
Computer Name     :
Full Path         : C:\Windows\Minidump\040115-21481-01.dmp
Major Version     : 15
Dump File Size    : 1,001,424
Dump File Time    : 4/1/2015 9:27:00 PM
Dump File         : 033115-18891-01.dmp
Crash Time        : 3/31/2015 9:33:53 AM
Parameter 2       : fffffa80`06b0c060
Parameter 4       : fffffa80`0ba684f0
Processor         : x64
Stack Address 1   :
Stack Address 2   :
Stack Address 3   :
Computer Name     :
Full Path         : C:\Windows\Minidump\033115-18891-01.dmp
Major Version     : 15
Dump File Size    : 958,704
Dump File Time    : 3/31/2015 2:14:05 PM
Thank you,
Venu
2015-04-08T14:50:35+00:00
Were you running the Microsoft Safety scanner, when this occurred? Please run driver verifier (DV) per the instructions in the link below.
Note: Make sure to read and remember the steps to reset DV in the event of a crash, and post a link to the newly generated crash dump here.
Driver Verifier-- tracking down a mis-behaving driver. Co-Authored by ZigZag3143& JMH3143
http://answers.microsoft.com/en-us/windows/wiki/windows\_other-system/driver-verifier-tracking-down-a-mis-behaving/f5cb4faf-556b-4b6d-95b3-c48669e4c983
42 additional answers
    2015-04-08T14:01:12+00:00
    Venu
    For the record both Bit Defender and Checkpoint were providing a software firewall so you were duplicating this facility. The System Information file you uploaded was actually the output from Speccy which is something different. They do provide similar information but they are not identical.
    2015-04-08T14:34:13+00:00
    Hi Gerry and XP Rocks,
    I just received another BSOD which was slightly different.
    Dump File         : 040815-44163-01.dmp
    Crash Time        : 4/8/2015 6:38:46 PM
    Bug Check String  : SYSTEM_SERVICE_EXCEPTION
    Bug Check Code    : 0x0000003b
    Parameter 1       : 00000000`c0000005
    Parameter 2       : fffff880`016e566f
    Parameter 3       : fffff880`077b87f0
    Caused By Driver  : ndis.sys
    Caused By Address : ndis.sys+5366f
    File Description  : NDIS 6.20 driver
    File Version      : 6.1.7600.16385 (win7_rtm.090713-1255)
    Processor         : x64
    Stack Address 1   :
    Stack Address 2   :
    Stack Address 3   :
    Computer Name     :
    Full Path         : C:\Windows\Minidump\040815-44163-01.dmp
    Major Version     : 15
    Dump File Size    : 352,200
    Dump File Time    : 4/8/2015 6:40:53 PM
    The minidump file 040815-44163-01.dmp has been uploaded to onedrive (http://1drv.ms/1yd0G9L).
    I will uninstall the Checkpoint VPN and try if I am still getting the BSOD errors.
    Thank you,
    Venu
    2015-04-18T05:09:59+00:00
    Sorry for responding late - I was out of station for a few days.
    I tried uninstalling Bitdefender and replaced with Trend Micro - the number of BSODs reduced (in fact there weren't any till yesterday). However, I encountered another error yesterday.
    The mini dump files are saved on onedrive - http://1drv.ms/1zrDwHC
    Dump File         : 041715-137951-01.dmp
    Crash Time        : 4/17/2015 12:23:56 PM
    Bug Check String  : PAGE_FAULT_IN_NONPAGED_AREA
    Bug Check Code    : 0x00000050
    Parameter 1       : fffff8a0`07803430
    Parameter 2       : 00000000`00000000
    Parameter 3       : fffff800`03810b23
    Caused By Address : ntoskrnl.exe+72a40
    File Version      : 6.1.7601.18798 (win7sp1_gdr.150316-1654)
    Processor         : x64
    Crash Address     : ntoskrnl.exe+72a40
    Stack Address 1   :
    Stack Address 2   :
    Stack Address 3   :
    Computer Name     :
    Full Path         : C:\Windows\Minidump\041715-137951-01.dmp
    Major Version     : 15
    Dump File Size    : 404,960
    Dump File Time    : 4/17/2015 12:28:44 PM
    Dump File         : 040915-22136-01.dmp
    Crash Time        : 4/9/2015 4:54:36 PM
    Bug Check String  : SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
    Bug Check Code    : 0x1000007e
    Parameter 1       : ffffffff`80000003
    Parameter 2       : fffff800`036bbcd0
    Parameter 3       : fffff880`045500d8
    Parameter 4       : fffff880`0454f930
    Caused By Driver  : Wdf01000.sys
    Caused By Address : Wdf01000.sys+1630
    File Description  : Kernel Mode Driver Framework Runtime
    File Version      : 1.11.9200.16384 (win8_rtm.120725-1247)
    Processor         : x64
    Crash Address     : ntoskrnl.exe+6ccd0
    Stack Address 1   :
    Stack Address 2   :
    Stack Address 3   :
    Computer Name     :
    Full Path         : C:\Windows\Minidump\040915-22136-01.dmp
    Major Version     : 15
    Dump File Size    : 262,144
    Dump File Time    : 4/9/2015 4:56:10 PM
    Dump File         : 040915-122117-01.dmp
    Crash Time        : 4/9/2015 8:31:28 AM
    Bug Check String  : DRIVER_VERIFIER_IOMANAGER_VIOLATION
    Bug Check Code    : 0x000000c9
    Parameter 1       : 00000000`00000226
    Parameter 2       : fffff880`066e7410
    Parameter 3       : fffff980`4517a990
    Caused By Driver  : trufos.sys
    Caused By Address : trufos.sys+2410
    File Description  :
    Product Name      :
    Company           :
    File Version      :
    Processor         : x64
    Stack Address 1   :
    Stack Address 2   :
    Stack Address 3   :
    Computer Name     :
    Full Path         : C:\Windows\Minidump\040915-122117-01.dmp
    Major Version     : 15
    Dump File Time    : 4/9/2015 4:46:55 PM
    Dump File         : 040915-32947-01.dmp
    Crash Time        : 4/9/2015 12:55:33 AM
    Bug Check String  : DRIVER_PAGE_FAULT_IN_FREED_SPECIAL_POOL
    Bug Check Code    : 0x000000d5
    Parameter 1       : fffff980`31ffef34
    Parameter 3       : fffff880`013cc2d8
    Processor         : x64
    Stack Address 1   :
    Stack Address 2   :
    Stack Address 3   :
    Computer Name     :
    Full Path         : C:\Windows\Minidump\040915-32947-01.dmp
    Major Version     : 15
    Dump File Time    : 4/9/2015 8:20:42 AM
    Thank you,
    Venu
    2015-04-18T09:41:24+00:00
    ZoneAlarm or VPV Checkpoint is still there! Please remove it as previously suggested.
      Image path: \SystemRoot\system32\DRIVERS\vsdatant.sys
        Image name: vsdatant.sys
        Timestamp:      Mon Aug 13 09:50:44 2012 (50290634)
        CheckSum:         00072108
