Windows 7 Ultimate 64 bit - Help with BSOD!!
2015-04-08T03:48:26+00:00
Hi All,
I am getting recurring BSOD errors on my Desktop. There are no recent hardware / software changes / additions other than windows updates.
Please help me with this.
OS: Windows 7 Ultimate 64bit - 8GB DDR3 RAM (with all latest Microsoft updates installed)
Motherboard and Processor - i7-870 processor on Intel DP55KG Motherboard
Dump File         : 040815-21590-01.dmp
Crash Time        : 4/8/2015 6:48:51 AM
Bug Check String  : BAD_POOL_HEADER
Bug Check Code    : 0x00000019
Parameter 1       : 00000000`00000003
Parameter 2       : fffffa80`0608fe20
Parameter 3       : fffffa80`0608fe20
Parameter 4       : 00000000`00000000
Caused By Driver  : ntoskrnl.exe
Caused By Address : ntoskrnl.exe+74ec0
File Description  : NT Kernel & System
Product Name      : Microsoft® Windows® Operating System
Company           : Microsoft Corporation
File Version      : 6.1.7601.18741 (win7sp1_gdr.150202-1526)
Processor         : x64
Crash Address     : ntoskrnl.exe+74ec0
Stack Address 1   :
Stack Address 2   :
Stack Address 3   :
Computer Name     :
Full Path         : C:\Windows\Minidump\040815-21590-01.dmp
Processors Count  : 8
Major Version     : 15
Minor Version     : 7601
Dump File Size    : 315,872
Dump File Time    : 4/8/2015 6:51:06 AM
Dump File         : 040815-24601-01.dmp
Crash Time        : 4/8/2015 2:36:33 AM
Bug Check String  : IRQL_NOT_LESS_OR_EQUAL
Bug Check Code    : 0x0000000a
Parameter 1       : ffffffff`ffffffd8
Parameter 2       : 00000000`00000002
Parameter 3       : 00000000`00000000
Parameter 4       : fffff800`0368924b
Processor         : x64
Stack Address 1   :
Stack Address 2   :
Stack Address 3   :
Computer Name     :
Full Path         : C:\Windows\Minidump\040815-24601-01.dmp
Major Version     : 15
Dump File Size    : 352,224
Dump File Time    : 4/8/2015 2:38:12 AM
Dump File         : 040115-21481-01.dmp
Crash Time        : 4/1/2015 8:08:42 PM
Bug Check String  : DRIVER_POWER_STATE_FAILURE
Bug Check Code    : 0x0000009f
Parameter 2       : fffffa80`06b03a10
Parameter 3       : fffff800`00b9a518
Parameter 4       : fffffa80`0694f0b0
Processor         : x64
Stack Address 1   :
Stack Address 2   :
Stack Address 3   :
Computer Name     :
Full Path         : C:\Windows\Minidump\040115-21481-01.dmp
Major Version     : 15
Dump File Size    : 1,001,424
Dump File Time    : 4/1/2015 9:27:00 PM
Dump File         : 033115-18891-01.dmp
Crash Time        : 3/31/2015 9:33:53 AM
Parameter 2       : fffffa80`06b0c060
Parameter 4       : fffffa80`0ba684f0
Processor         : x64
Stack Address 1   :
Stack Address 2   :
Stack Address 3   :
Computer Name     :
Full Path         : C:\Windows\Minidump\033115-18891-01.dmp
Major Version     : 15
Dump File Size    : 958,704
Dump File Time    : 3/31/2015 2:14:05 PM
Thank you,
Venu
2015-04-08T14:50:35+00:00
Were you running the Microsoft Safety scanner, when this occurred? Please run driver verifier (DV) per the instructions in the link below.
Note: Make sure to read and remember the steps to reset DV in the event of a crash, and post a link to the newly generated crash dump here.
Driver Verifier-- tracking down a mis-behaving driver. Co-Authored by ZigZag3143& JMH3143
http://answers.microsoft.com/en-us/windows/wiki/windows\_other-system/driver-verifier-tracking-down-a-mis-behaving/f5cb4faf-556b-4b6d-95b3-c48669e4c983
42 additional answers
    2015-04-08T11:23:31+00:00
    You Intel 82577LM Gigabit NIC driver was flagged as the culprit, but I suspect that this is happening as a result of a conflict between BitDefender an a Zonealarm module. I would remove both and install Microsoft Security Essentials with Windows firewall.
    STACK_COMMAND:  kb
    FOLLOWUP_NAME:  MachineOwner
    FAILURE_BUCKET_ID:  X64_0x9F_3_e1k62x64_IMAGE_pci.sys
    Followup: MachineOwner
    If you can not find the Zone Alarm module, download "autoruns" and use it to locate and disable or delete the driver, after making certain that all Microsoft entries have been hidden, to eliminate the possibility of a mistake.(instructions in the youtube video link below.)
    Autoruns for Windows
    v13.01
    This utility, which has the most comprehensive knowledge of auto-starting locations of any startup monitor, shows you what programs are configured to run during system bootup or login, and shows you the entries in the order Windows processes them. These programs include ones in your startup folder, Run, RunOnce, and other Registry keys. You can configure Autoruns to show other locations, including Explorer shell extensions, toolbars, browser helper objects, Winlogon notifications, auto-start services, and much more. Autoruns goes way beyond the MSConfig utility bundled with Windows Me and XP.Autoruns' Hide Signed Microsoft Entries option helps you to zoom in on third-party auto-starting images that have been added to your system and it has support for looking at the auto-starting images configured for other accounts configured on a system
    https://technet.microsoft.com/en-us/sysinternals/bb963902.aspx
    How to use Autoruns.
    https://www.youtube.com/watch?v=HhtSDsQYi28
     Image path: \SystemRoot\system32\DRIVERS\vsdatant.sys
        Image name: vsdatant.sys
        Timestamp:        Mon Aug 13 09:50:44 2012 (50290634)
        CheckSum:         00072108
        ImageSize:        00094000
    Uninstall Tools for Bitdefender Products.
    http://www.bitdefender.com/uninstall/
    http://windows.microsoft.com/en-US/windows/security-essentials-download
    Machine ID Information [From Smbios 2.6, DMIVersion 38, Size=1797]
    BiosMajorRelease = 0
    BiosMinorRelease = 0
    FirmwareMajorRelease = 0
    FirmwareMinorRelease = 0
    BiosVendor = Intel Corp.
    BiosVersion = KGIBX10J.86A.5936.2011.0630.2250
    BiosReleaseDate = 06/30/2011
    SystemManufacturer = Enter System Manufacturer
    SystemProductName = Enter System Product Name
    SystemVersion = Enter System Version
    BaseBoardManufacturer = Intel Corporation
    BaseBoardProduct = DP55KG
    BaseBoardVersion = AAE47218-404
    Intel DP55KG
    https://downloadcenter.intel.com/search?keyword=Intel%c2%ae+Desktop+Board+DP55KG
    If the system continues to crash after taking the steps above, please run driver verifier (DV) per the instructions in the link below.
    2015-04-08T11:44:30+00:00
    Hi Gerry,
    Thank you for the response. I have posted the minidump files, driver view file and system information file on onedrive.
    http://1drv.ms/1ycINbc
    Please let me know in case of any questions.
    Best regards,
    Venu
    2015-04-08T11:50:35+00:00
    Hi XP Rocks,
    Thank you for the analysis. I have posted the Driver View file on onedrive (http://1drv.ms/1ycINbc)
    I believe the Zonealarm module is part of the VPN (Checkpoint) that I have installed. Can I just remove the VPN and keep the Bitdefender (since I have already paid for 3 years).
    I will also remove the NIC driver and take the latest one for DP55KG board from the Intel website.
    I will try doing these and let you know the status. Please let me know if the BitDefender needs to be removed.
    Best regards,
    Venu
    2015-04-08T11:55:16+00:00
    Yes, you can try all those things, but if it continues to crash, now you have an idea of what to do.
