Hey,
I made a video on how to fix this issue.
You can watch the video here : https://www.youtube.com/watch?v=F4xQMlZEyr0
Hope that it helps!
Hello all.
I have come upon a recent issue with my computer. My microphone automutes itself , and the levels go down to zero as well. Even if I manually adjust levels to 100 and unmute it resets and automutes again after a short time ( less than a minute ). I have not updated drivers but I cannot see them being the issue because I had zero issues yesterday why would the problem begin today I did not update or install any new programs. I have tried another mic plugged in through the standard jack and it does the same thing. My mic is a logitech webcam USB. Any suggestions? I cant seem to find any solutions on the web other than the obvious " Oh unmute it" .
I feel this is a windows 7 issue and this is why I have come here.
Hey,
Hope that it helps!
Can we please have a fix for windows 7? I don't have a svchost.exe file in my task manager. I'm running a Dell computer, if that helps.
That solution for svchost didn't work - nothing worked, have to reinstall as I have spend far to much time trying all this solutions to no positive outcome, sadly while intentions were good, a waste of time, one would think Microsoft would have an answer for their shortcoming, you would think.
If you are going to re-install windows, please let me know if this works. I have a lot of stuff on my computer to move and then move back. And I don't want to waste anymore time than necessary. I think I've given up hope of being able to use the mic on this pc again.
I am not re-installing
I did the suggested
Type taskkill (space) /F (space) /PID(insert the PID number) then hit enter
You have to do it for everyone on them (PID#)
