HP Stream Gift Card
2015-01-31T17:44:09+00:00
How do a receive my $25 Microsoft store gift card, for purchasing a HP Stream.
Windows for home | Previous Windows versions | Microsoft Store
2015-02-01T08:22:57+00:00
Congratulations on your purchase of Hp Stream.
Please note that the "Gift Card Promotional Offer" might be a Limited Time Offer and available in select countries. To redeem, please visit www.Microsoft.com/HPStream for information on the offer, availability, and terms. Internet services will be required for the process of redemption and are not included. Also a valid Microsoft account is required to install apps from the Windows App Store.
For more information please visit the Microsoft Store Web link:
http://www.microsoftstore.com/store/msusa/en_US/home
Hope this helps.
85 additional answers
    2015-08-04T20:20:38+00:00
    yes, what does one do? or is this a gimmick???
    2015-08-05T02:29:21+00:00
    No, its not a gimmick. To get the $25 MS Store card, using your HP device sign-in using Internet Explorer and follow the instructions http://microsoft.com/hpstream  . it'll guide you to change some settings in IE to detect your HP Stream is eligible for it or not.
    Once you get the card number, you have to redeem it by 31st Dec 2015 and have to spend within 3 months.
    I think this you have to do before upgrading to Windows 10 else it'll not be detected correctly.
    2015-08-06T21:58:44+00:00
    how did you get it to work?! I still cant get mine to work :(
    2015-08-11T19:46:37+00:00
