INTELAUDIO\FUNC_01&VEN_8086&DEV_280A&SUBSYS_80860101&REV_1000
I just Installed windows 10 this morning everything runs fine expect for the sound, where is it?
I have tried troubleshooting the problem its says it has fixed it but the little red cross is still is cuddling into the speaker icon. I have tried everything uninstalling and installing the sound again.....does nothing. I even disabled and enabled it......does nothing. I must tell you I am not computer literate and would love for someone to just give me simple instructions and a step by step guide on how to actually fix this problem.
IDT - Audio Device - IDT High Definition Audio CODEC - Error 0x8007001f <<<<<<<<< this is the error that keeps appearing.
Help me Obi windows Kenobi you're my only hope :)
* Moved by the Moderator to a more appropriate forum category
These are not the drivers you're looking for. :-)
A couple of things to try and figure this out...
What kind of PC is this?
Could you please post your audio hardware ID here?
- Run Device Manager
- Go to Sound, video and game controllers
- Double-click your audio device
- Go to the Details tab
- Select Hardware IDs
- Right-click to copy them and then paste them in a reply here
Can you try switching to the built-in Windows driver for now?
The Alliance needs you, DarrenTempleton...
my hardware ID is
HARDWARE ID'S
HDAUDIO\FUNC_01&VEN_111D&DEV_76E5&SUBSYS_1179FA4D HDAUDIO\FUNC_01&VEN_111D&DEV_76E5&SUBSYS_1179FA4D&REV_1003
No Audio Output Device Installed
HDAUDIO\FUNC_01&VEN_111D&DEV_7676&SUBSYS_103C2AE0&REV_1001
HDAUDIO\FUNC_01&VEN_111D&DEV_76C7&SUBSYS_103C3AB5&REV_1001
