No audio Output Device for Windows 10
2015-07-30T16:39:28+00:00
I just Installed windows 10 this morning everything runs fine expect for the sound, where is it?
I have tried troubleshooting the problem its says it has fixed it but the little red cross is still is cuddling into the speaker icon. I have tried everything uninstalling and installing the sound again.....does nothing. I even disabled and enabled it......does nothing. I must tell you I am not computer literate and would love for someone to just give me simple instructions and a step by step guide on how to actually fix this problem.
IDT - Audio Device - IDT High Definition Audio CODEC - Error 0x8007001f <<<<<<<<< this is the error that keeps appearing.
Help me Obi windows Kenobi you're my only hope :)
* Moved by the Moderator to a more appropriate forum category
    2016-08-02T23:50:45+00:00
    HDAUDIO\FUNC_01&VEN_111D&DEV_76E0&SUBSYS_103C2AFA&REV_1003
    2016-08-07T10:21:14+00:00
    I had three codes:
    ACPI\VEN_8086&DEV_22A8&SUBSYS_10251021
    ACPI\808622A8
    *808622A8
    2016-08-13T19:27:34+00:00
    "HDAUDIO\FUNC_01&VEN_1002&DEV_791A&SUBSYS_00791A00&REV_1000
    HDAUDIO\FUNC_01&VEN_1002&DEV_791A&SUBSYS_00791A00"
  4. Deleted
    2016-10-14T02:43:17+00:00
    Hi!
    For those of you that have no sound with dev_7605, the following linked worked for me:
    https://support.microsoft.com/en-ca/instantanswers/a183aa8b-0eac-4566-867a-98d2761a770d/fix-sound-problems
    In device manager, the sound card was listed "IDT High definition audio device" with an exclamation mark in front of it.
