hey chief I have an hp touchsmart 610 model.... same issue any advice?
No audio Output Device for Windows 10
I just Installed windows 10 this morning everything runs fine expect for the sound, where is it?
I have tried troubleshooting the problem its says it has fixed it but the little red cross is still is cuddling into the speaker icon. I have tried everything uninstalling and installing the sound again.....does nothing. I even disabled and enabled it......does nothing. I must tell you I am not computer literate and would love for someone to just give me simple instructions and a step by step guide on how to actually fix this problem.
IDT - Audio Device - IDT High Definition Audio CODEC - Error 0x8007001f <<<<<<<<< this is the error that keeps appearing.
Help me Obi windows Kenobi you're my only hope :)
* Moved by the Moderator to a more appropriate forum category
2015-09-01T01:06:40+00:00 -
2015-09-02T22:29:17+00:00 HDAUDIO\FUNC_01&VEN_8086&DEV_2806&SUBSYS_80860101&REV_1000
2015-09-04T14:59:26+00:00 HDAUDIO\FUNC_01&VEN_111D&DEV_76C7&SUBSYS_103C3AB6&REV_1001
2015-09-08T11:52:10+00:00 Problem: After updating to windows 10 from windows 7 "No audio output device is installed"
My laptop is an ASUS U36SD
Here's my audio hardware id:
HDAUDIO\FUNC_01&VEN_10EC&DEV_0269&SUBSYS_10431BA3&REV_1001
2015-09-11T20:48:36+00:00 HDAUDIO\FUNC_01&VEN_11D4&DEV_194A&SUBSYS_103C30E6&REV_1004
