I have a Samsung np350v5c laptop and have always been able to use the cd/dvd drive. I have been on windows 8.1 for a while but have noticed over the last month that the cd drive does not work anymore. If you enter a cd it doesn't recognise it, the d drive
doesn't appear in windows explorer etc. From browsing this forum I found a solution in 2012 to change registry by adding
reg.exe add "HKLM\System\CurrentControlSet\Services\atapi\Controller0" /f /v EnumDevice1 /t REG_DWORD /d 0x00000001
to cmd prompt which I did and rebooted. Initially the d drive reappeared, I left the laptop in sleep mode overnight but when I opened it up the d drive had disappeared again.
Under device manager it says the drive is ST1000LM024_HN-M101MBB. I have tried uninstalling the driver and reinstalling, updating (says up to date) but no joy.
My partner has the exact same laptop so I checked his and his cd drive isn't working either so it must be a conflict between with windows 8.1 and not a failing cd drive.
Does anyone have any new ideas please?
