bsod kernal power failure bugcheck code 159
2015-05-16T16:40:34+00:00
Hope someone can help caught a blue screen this morning . I have a ASUS laptop Model g73jw.  this is the info from the crash Can Someone Please help
MIke
Log Name:      System
Source:        Microsoft-Windows-Kernel-Power
Date:          5/16/2015 10:03:18 AM
Event ID:      41
Task Category: (63)
Level:         Critical
Keywords:      (2)
User:          SYSTEM
Computer:      mikes-pc
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Xml:
< Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
  <System>
    <Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
    <EventID>41</EventID>
    <Version>2</Version>
    <Level>1</Level>
    <Task>63</Task>
    <Opcode>0</Opcode>
    <Keywords>0x8000000000000002</Keywords>
    <TimeCreated SystemTime="2015-05-16T15:03:18.836807600Z" />
    <EventRecordID>419399</EventRecordID>
    <Correlation />
    <Execution ProcessID="4" ThreadID="8" />
    <Channel>System</Channel>
    <Computer>mikes-pc</Computer>
    <Security UserID="S-1-5-18" />
  </System>
  <EventData>
    <Data Name="BugcheckCode">159</Data>
    <Data Name="BugcheckParameter1">0x3</Data>
    <Data Name="BugcheckParameter2">0xfffffa800bfafa00</Data>
    <Data Name="BugcheckParameter3">0xfffff80000b9a518</Data>
    <Data Name="BugcheckParameter4">0xfffffa80105cd3d0</Data>
    <Data Name="SleepInProgress">false</Data>
    <Data Name="PowerButtonTimestamp">0</Data>
  </EventData>
< /Event>
2015-07-13T11:02:56+00:00
Mike
Logitech M510 – Do you have the latest drivers?
http://support.logitech.com/product/wireless-mouse-m510#download
Testing to see if the Event 17 warnings stop may take a time judging by the frequency in which they are reported. Otherwise I think all that should be done is to wait and see if another blue screen error occurs. I do not think that reinstalling Windows is justified.
43 additional answers
    2015-06-17T02:20:07+00:00
    I could not find the dump file for 6/15 I suspect it was never created. I can run the verifier again if you want me to. not too sure how I created the link it must have been from the day before.
    uploaded all of the dump files (30days) from the path you instructed me to. I don't think I restored since that time I did restore around the end of April early May I just cant remember when
    if one comes up asdsm.sys as the problem I changed it to asdsm.old in order to get the computer to run (cant remember the bug check code)
    I originally blew this thing out a couple of months ago or so.  the fan used to really scream and it used to get extremely hot.,  I did this after I put a new hard drive in. then again about a month ago. After I shut the computer down tonight I will blow it out again.
    thank you for all the help
    https://onedrive.live.com/redir?resid=72040ac237b79dd5!135&authkey=!ADCqdbyO7gcwFrs&ithint=folder%2cdmp
    mike
    2015-06-17T12:18:13+00:00
    Mike
    0: kd> !irp fffffa8007553b80
    Irp is active with 13 stacks 10 is current (= 0xfffffa8007553ed8)
     No Mdl: No System Buffer: Thread 00000000:  Irp stack trace.       cmd  flg cl Device   File     Completion-Context [  0, 0]   0  0 00000000 00000000 00000000-00000000
                  Args: 00000000 00000000 00000000 00000000 [  0, 0]   0  0 00000000 00000000 00000000-00000000
                         <snipped>
                  Args: 00000000 00000000 00000000 00000000>[ 16, 2]   0 e0 fffffa800b4ea8b0 00000000 fffff880067ce68c-00000000 Success Error Cancel       \Driver\usbccgp STREAM!SCDevWakeCompletionRoutine
                  Args: 00000000 00000001 00000001 00000000
     [ 16, 2]   0  1 fffffa800b40d050 00000000 00000000-00000000    pending          Unable to load image snp2uvc.sys, Win32 error 0n2
    *** WARNING: Unable to verify timestamp for snp2uvc.sys
    *** ERROR: Module load completed but symbols could not be loaded for snp2uvc.sys \Driver\SNP2UVC
                  Args: 00000000 00000001 00000001 00000000 [ 16, 2]   0 e1 fffffa800b536060 00000000 fffff80003c6f0d0-fffffa800f794d40 Success Error Cancel pending
           \Driver\ksthunk     nt!IopUnloadSafeCompletion
    Args: 00000000 00000001 00000001 00000000 [  0, 0]   0  0 00000000 00000000 00000000-fffffa800a6918f0
    snp2uvc.sys = UVC Camera Streaming Driver from Sonix Technology.
    You need to update or remove this driver.
    https://www.asus.com/ROG_ROG/G73Jw/HelpDesk_Download/
    Please download and run Driver View and upload a copy of the report it produces to your OneDrive. To get a report on all drivers select Edit, Select All followed by File, Save Selected Items.
    http://www.nirsoft.net/utils/driverview.html
    2015-06-19T03:56:04+00:00
    the problem when up daateing at asus I believe is different drivers are at different places
    I an currenly running driver update  5.8.55133.208
    driver 5.8.55133.208 is at
    http://support.asus.com/Download.aspx?SLanguage=en&m=CAMERA&p=3&ft=28&os=30
    and driver 5.8.54000.206 is at
    should I go back to the older driver or just eliminate the camera completely and look to reinstall it later ?  I don't use it even when I do it displays up side down any way
    I did run driver view and put it on one drive here is the link
    https://onedrive.live.com/redir?resid=72040AC237B79DD5!105&authkey=!AF20fohFcwNB\_uM&ithint=folder%2ctxt
    2015-06-19T08:28:53+00:00
    Mike
    I don't use it even when I do it displays upside down any way
    The video captured by the ASUS Notebook's camera is upside down. How to resolve the issue?
    https://www.asus.com/support/FAQ/109836/
