bsod kernal power failure bugcheck code 159
2015-05-16T16:40:34+00:00
Hope someone can help caught a blue screen this morning . I have a ASUS laptop Model g73jw.  this is the info from the crash Can Someone Please help
MIke
Log Name:      System
Source:        Microsoft-Windows-Kernel-Power
Date:          5/16/2015 10:03:18 AM
Event ID:      41
Task Category: (63)
Level:         Critical
Keywords:      (2)
User:          SYSTEM
Computer:      mikes-pc
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Xml:
< Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
  <System>
    <Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
    <EventID>41</EventID>
    <Version>2</Version>
    <Level>1</Level>
    <Task>63</Task>
    <Opcode>0</Opcode>
    <Keywords>0x8000000000000002</Keywords>
    <TimeCreated SystemTime="2015-05-16T15:03:18.836807600Z" />
    <EventRecordID>419399</EventRecordID>
    <Correlation />
    <Execution ProcessID="4" ThreadID="8" />
    <Channel>System</Channel>
    <Computer>mikes-pc</Computer>
    <Security UserID="S-1-5-18" />
  </System>
  <EventData>
    <Data Name="BugcheckCode">159</Data>
    <Data Name="BugcheckParameter1">0x3</Data>
    <Data Name="BugcheckParameter2">0xfffffa800bfafa00</Data>
    <Data Name="BugcheckParameter3">0xfffff80000b9a518</Data>
    <Data Name="BugcheckParameter4">0xfffffa80105cd3d0</Data>
    <Data Name="SleepInProgress">false</Data>
    <Data Name="PowerButtonTimestamp">0</Data>
  </EventData>
< /Event>
2015-07-13T11:02:56+00:00
Mike
Logitech M510 – Do you have the latest drivers?
http://support.logitech.com/product/wireless-mouse-m510#download
Testing to see if the Event 17 warnings stop may take a time judging by the frequency in which they are reported. Otherwise I think all that should be done is to wait and see if another blue screen error occurs. I do not think that reinstalling Windows is justified.
43 additional answers
    2015-05-30T21:23:41+00:00
    Gerry-
    I apologize for not getting back sooner work was very busy at work  and I did not have much time this week. I did get the following done
    I ran adw again and I didn't come up with anything, it looks like all was removed
    I deleted the files that were highlighted in yellow from Autoruns
    You were right the malewarebytes is the free trial for premium
    I have uploaded the application and system log here is the link
    ttps://onedrive.live.com/redir?resid=72040ac237b79dd5%21105
    I did catch the blue screen again same as before code 159
    thank you for all of the help so far.
    Mike
    2015-06-07T19:08:52+00:00
    Gerry-
    not sure if you have finished your investigation.  I was told to update my camera driver.  I did this today and am not sure if it will work yet as I have not run the computer after the fix.  I will do this today and over the next couple of days.  hope to hear from you soon. I did unmark that as the answer as I don't know if it is the answer yet.  not too sure how the answer box was checked.
    MIke
    2015-06-07T19:11:46+00:00
    Hello Auggy-
    Just updated my driver like you suggested will run the computer over the next few days. to see if I catch another blue screen and will get back to you.  Thank you for the help
    MIke-
    2015-06-08T04:04:04+00:00
    OK, good luck!
