printer not showing in devices and printers
2015-01-01T13:41:30+00:00
my printer works fine with installed software but does not show in devices and printers and cannot print emails or any web content
it shows in device manager
    2015-01-11T11:58:29+00:00
    Hello Ron,
    Thank you for the input.
    I hope that your findings may help other community members to resolve similar issues.
    I appreciate your research.
    Thank you
    2015-01-11T14:34:10+00:00
    Hi
    uninstalled printer tried to re install through link would not connect it also  tried HP printer install failure help software still would not connect
    I understand what should show in devices and printers problem is nothing at all shows except when using in safe mode
    Ron
    2015-01-11T14:58:04+00:00
    Did you use the Software and Driver Removal Utility?
    Quote "I understand what should show in devices and printers problem is nothing at all shows except when using in safe mode"  Not use why you address this comment to my post.
    You still have the problem with corrupt files to deal with?  That may or may not have something to do with the installing the printer problem.
    The other thing that you might try is using Windows Cleanup
    2015-01-11T16:03:37+00:00
    Hello Ron,
    Thank you for the update.
    I would suggest you to disable antivirus software and check the issue.
    Refer:
    Disable antivirus software
    http://windows.microsoft.com/en-us/windows/disable-antivirus-software#1TC=windows-7
    Note: Antivirus software can help protect your computer against viruses and other security threats. In most cases, you shouldn't disable your antivirus software. If you have to temporarily disable it to install other software, you should re-enable it as soon as you're done. If you're connected to the Internet or a network while your antivirus software is disabled, your computer is vulnerable to attacks.
    I hope this helps.
    Thank you
    2015-01-11T16:09:52+00:00
    hi
    I have now deleted and re installed relevant software from HP and printer  installed successfully but not showing in devices and printers I have hp software which allows  me to set default printer etc so do not have any problems using it
    teredo tunnelling device not working code 10
    Ron
