Constant BSOD Errors
2015-04-26T23:06:53+00:00
I believe I may have a faulty driver, but I need help on finding said driver and if I can fix it personally or not.
The other day I installed a new game (skyrim). Ever since, I've been getting BSOD's for different errors. I did not get one while playing the game. I got a few that were different than one another, but have been getting the same one recently. I'm posting this in Safe Mode.
The errors were in order:
  • BAD_POOL_CALLER
  • SPECIAL_POOL_DETECTED_MEMORY_CORRUPTION (gotten this one a couple times in a row within minutes of computer running. Is the most recent)
  • KMODE_EXCEPTION_NOT_HANDLED (computer reverted back to before skyrim was installed after this one. I did not revert it myself. Happened automatically)
Please, help would be greatly appreciated.
I'm deployed and this is pretty much the only way I have of talking to family. Thank you!
    2015-05-08T00:27:29+00:00
    And what do I do after I disable it?
    Wait and see if you are getting the same errors and if you are, reinstall your AMD Display driver without CCC.
    2015-05-08T00:56:19+00:00
    https://onedrive.live.com/redir?resid=BA908D345934CFAD!1039&authkey=!AEGi0FQegs8fYTw&ithint=file%2cdmp
    1. Restarted normally
    2. Disabled AMD Fuel service immediately
    3. Pulled up google chrome webpage and things were going incredibly slower than normal
    4. BSOD with KMODE EXCEPTION NOT HANDLED ERROR
    Going to go ahead and uninstall then reinstall the display driver like you stated but wanted to post this minidump to see if you could get any info. from it while I do this.
    2015-05-08T02:20:31+00:00
    https://onedrive.live.com/redir?resid=BA908D345934CFAD!1040&authkey=!ADfqez-6u7eagZ0&ithint=file%2cdmp
    Same error as last dump I posted. Kmode
    I uninstalled the driver but for some reason catalyst stayed. Tried looking for methods to uninstall but none could be found.
    Here's the minidump to the crash after reinstall
    2015-05-08T06:06:01+00:00
    1: kd> !sysinfo machineid
    Machine ID Information [From Smbios 2.7, DMIVersion 39, Size=1591]
    BiosMajorRelease = 15
    BiosMinorRelease = 18
    FirmwareMajorRelease = 4
    FirmwareMinorRelease = 68
    BiosVendor = Insyde
    BiosVersion = F.12< currently installed
    BiosReleaseDate = 09/26/2013
    SystemManufacturer = Hewlett-Packard
    SystemProductName = HP ENVY TS m6 Sleekbook
    SystemFamily = 103C_5335KV G=N L=CON B=HP S=ENV
    SystemVersion = 0883100022305B00000320100
    SystemSKU = E0L06UA#ABA
    BaseBoardManufacturer = Hewlett-Packard
    BaseBoardProduct = 1995
    BaseBoardVersion = 04.44
    I've just noticed that there have been a few BIOS Revisions since F.12, including one that was (F.13)strongly recommended for you notebook by HP for Security reasons and has not been applied by you.
    The most current BIOS Revision is Ver:
    HP Notebook System BIOS Update (AMD Processors)
    Version :
    F.15 A
    Language:
    English
    Details
    This package contains the WinFlash utility and a system BIOS image for the supported notebook models running a supported operating system. The WinFlash utility is used to locally flash the system BIOS (ROM) on notebooks operating in a Microsoft Windows environment.
    File name:sp69822.exe
    Release details
    Released: Dec 1, 2014
    Version F.15 A
    Fix and enhancements
    • Provides improved security of UEFI code and variables.
    NOTE: HP strongly recommends promptly transitioning to this updated BIOS version which supersede all previous releases.
    Source: http://support.hp.com/us-en/drivers/selfservice/HP-ENVY-TouchSmart-m6-k000-Sleekbook/5375391/model/5447423
    Please apply the Update, after making sure that I have the correct system linked, and we'll go from there
    BIOS Disclaimer
    Updating BIOS should only be done if necessary (to solve a compatibility problem, for example). It can be a complicated process, and if an error occurs, your computer could be rendered inoperable. Be sure to follow the manufacturer's instructions exactly.
    2015-05-08T16:38:08+00:00
    So go ahead and update BIOS with this link you provided?
    http://ftp.hp.com/pub/softpaq/sp69501-70000/sp69822.exe
    I just want to verify and make sure this is what you're saying before I do it
