KB3023607 repeatedly removed by deepclean after KB3032359/KB3021952 (5.2mb ea) repeatedly offered/installed...
2015-03-15T22:40:10+00:00
KB3021952 (Feb "Cumulative" Update for IE) invloves a "bundled" update, it includes KB3023607. KB3032359 (March "Cumulative" Update for IE) is "bundled" it includes KB3040335 & KB3023607 (Again???) KB3032359 (allegedly) supersedes KB3021952 but both are needed along with KB3023607 to have a fully patched system. The problem occurs when Windows Update Cleanup (deepclean) is run after all patches are installed, it removes KB3023607, the "bundled" update as superseded :
2015-03-12 09:31:26, Info CBS Adding: Package_for_KB3023607~31bf3856ad364e35~amd64~~6.1.1.0
2015-03-12 09:31:31, Info CBS DC: Package_for_KB3023607~31bf3856ad364e35~amd64~~6.1.1.0: unique components: 58 Size: 20.54 MB (21,538,670 bytes) 2015-03-12 09:31:31, Info CBS Total size of superseded packages: 20.54 MB (21,538,670 bytes)
The KB's 3021952 & 3032359 (5.2mb) that are continually removed/re-offered/re-installed/re-removed... lather, rinse, repeat... are actually the child package component KB3023607 which gets removed by deepclean.
Thread information Updated see my reply Pg 6 March 30 2:48 AM
Windows for home | Other | Windows update
2015-03-30T23:03:36+00:00
At this point, it's evident that MS needs to investigate why Windows Update cleanup detection logic is ...broken (for lack of a better word) on some user's computer's only, there has to be a "missing link" ... I'm out of ideas and don't see too many here or elsewhere on the Innernetz
I have 2 options to correct the problem of KB3031432 not appearing in Installed Updates but yet the MSU installer returns the message KB3031432 is already installed... and the PendingDeletes that won't.
  1. Repair Install
  2. Restore from prior backup image (2/12/15, after Feb Black Patch Tuesday, tested on spare HDD.
Thank to everyone who replied, and a special thanks to "J"... seems you're one of the few I've seen around here that "gets" it.
Regards & Hasta la Bye-Bye
"Pink"
Edit to add: I have successfully restored my system to a previous backup image (2/12/15) prior to the "March Patch Madness" described in my OP, uninstalled the troublesome KB2852386 that enables Update Cleanup and re-applied the March '15 patches, all now appear in Installed Updates, including KB's 3023607, 3035131 & 3031432. Kindly mark this as "Answer" as I consider this matter resolved... if only temporarily.
Thank you.
127 additional answers
    2015-03-18T23:07:07+00:00
    1. No
    2. 3/11
    3. Yes via WU
    >>>If none of those Kernel updates is installed, something's verywrong with your install of Windows.<<<
    That being said...
    MS15-025FAQ's
    How is this update (3033929) related to the 3035131 update discussed in MS15-025?
    This update (3033929) shares affected binaries with the 3035131 update being released simultaneously via MS15-025. This overlap necessitates that one update supersede the other and, in this case, advisory update 3033929 supersedes update 3035131. Customers with automatic updating enabled should experience no unusual installation behavior; both updates should install automatically and both should appear in the list of installed updates...
    Installed thru WU (Check for updates but let me choose whether to...) All's well no? Not Quite...
    2015-03-11 09:59:57, Info                  CBS    Adding: Package_for_KB3023607~31bf3856ad364e35~amd64~~6.1.1.0
    2015-03-11 09:59:57, Info                  CBS    Adding: Package_for_KB3031432~31bf3856ad364e35~amd64~~6.1.1.0
    2015-03-11 10:00:03, Info                  CBS    Adding: Package_for_KB3035131~31bf3856ad364e35~amd64~~6.1.1.1
    If WU cleanup is removing critical valid Kernel updates as "superseded" there's something very wrong with Windows Updates.
    Edit 3/28 to italicize only.
  2. Deleted
    2015-03-19T06:42:11+00:00
    PA Bear MS MVP replied on March 18, 2015
    1] KB2785220 [Jan-13] was superseded (replaced) by KB3023562 [Feb-15] which, in turn, was superseded by KB3035131 [Mar-15].If none of those Kernel updates is installed, something's very wrong with your install of Windows.
    By "installed" which version of installed do you mean? Your version of installed?
    "Is KB3035131 listed in Installed Updates"...
    Or Windoze's:
    2015-03-19T14:03:13+00:00
    Oh Lordie, if only!!!
    Microsoft to axe Internet Explorer
