KB3023607 repeatedly removed by deepclean after KB3032359/KB3021952 (5.2mb ea) repeatedly offered/installed...
2015-03-15T22:40:10+00:00
KB3021952 (Feb "Cumulative" Update for IE) invloves a "bundled" update, it includes KB3023607. KB3032359 (March "Cumulative" Update for IE) is "bundled" it includes KB3040335 & KB3023607 (Again???) KB3032359 (allegedly) supersedes KB3021952 but both are needed along with KB3023607 to have a fully patched system. The problem occurs when Windows Update Cleanup (deepclean) is run after all patches are installed, it removes KB3023607, the "bundled" update as superseded :
2015-03-12 09:31:26, Info CBS Adding: Package_for_KB3023607~31bf3856ad364e35~amd64~~6.1.1.0
2015-03-12 09:31:31, Info CBS DC: Package_for_KB3023607~31bf3856ad364e35~amd64~~6.1.1.0: unique components: 58 Size: 20.54 MB (21,538,670 bytes) 2015-03-12 09:31:31, Info CBS Total size of superseded packages: 20.54 MB (21,538,670 bytes)
The KB's 3021952 & 3032359 (5.2mb) that are continually removed/re-offered/re-installed/re-removed... lather, rinse, repeat... are actually the child package component KB3023607 which gets removed by deepclean.
Thread information Updated see my reply Pg 6 March 30 2:48 AM
Windows for home | Other | Windows update
2015-03-30T23:03:36+00:00
At this point, it's evident that MS needs to investigate why Windows Update cleanup detection logic is ...broken (for lack of a better word) on some user's computer's only, there has to be a "missing link" ... I'm out of ideas and don't see too many here or elsewhere on the Innernetz
I have 2 options to correct the problem of KB3031432 not appearing in Installed Updates but yet the MSU installer returns the message KB3031432 is already installed... and the PendingDeletes that won't.
  1. Repair Install
  2. Restore from prior backup image (2/12/15, after Feb Black Patch Tuesday, tested on spare HDD.
Thank to everyone who replied, and a special thanks to "J"... seems you're one of the few I've seen around here that "gets" it.
Regards & Hasta la Bye-Bye
"Pink"
Edit to add: I have successfully restored my system to a previous backup image (2/12/15) prior to the "March Patch Madness" described in my OP, uninstalled the troublesome KB2852386 that enables Update Cleanup and re-applied the March '15 patches, all now appear in Installed Updates, including KB's 3023607, 3035131 & 3031432. Kindly mark this as "Answer" as I consider this matter resolved... if only temporarily.
Thank you.
127 additional answers
    2015-03-16T22:08:25+00:00
    A1) Yes I used the OEM Disc (5.23gb) but used the files to create a Customized bootable USB installation Media; removing Lang packs (1.65gb) support & Upgrade folders (70 mb). Drivers & other crapware are on a seperate "Drivers & Utilities" DVD which I've never used. I have up-to-date Drivers dl'd to an external backup drive which I used to install chipset, WiFi... etc. So no, Norton was not installed on the "Live" system & the VM I used for testing was stored on the aforementioned backup drive... besides, the VM was created by the DigitalRiver ISO I mentioned in 1b) :)
    For the sake of redundancy and to satisfy your Norton prepossession, I used the OEM DVD to install a fresh VM: Screenshot of installed Programs:
     A2) Noted.
    Norton is absolutely not to blame here. Can we now get off this preoccupation and get back on topic please? Thanks.
    As for your editing request I believe I edited my post somewhere between 3: 45- 4:10 but could be wrong. Your post was made @ 4:20. In any event I had the page open for quite some time without refreshing and was unaware of your post, sorry about that.
    EDIT @ 6:10 PM Eatern time: Screengrab not legible, that's Visual C++ 2008 x86, x64 & VMWare tools installed.
    EDIT 7:16 pm spelling
    2015-03-16T23:13:10+00:00
    FWIW...
    2015-03-17T01:22:57+00:00
    So you did NOT directly use the Dell OEM Recovery disk to do the clean install of Windows, is that correct?
    When signed in to your usual User Account (not in VM), is UAC disabled or...?
    Open IE11 (only) to this page & tell me the results: https://freakattack.com/clienttest.html
    2015-03-17T04:41:37+00:00
    Not directly, that is correct.
    On host computer I run as Administrator and UAC is disabled.
    Result of Freak attack check in IE11:
    FREAK Attack: Client Check
    Good News! Your browser appears to be safe from the FREAK attack.
