Edit to add: I have successfully restored my system to a previous backup image (2/12/15) prior to the "March Patch Madness" described in my OP, uninstalled the troublesome
KB2852386 that enables Update Cleanup and re-applied the March '15 patches, all now appear in Installed Updates, including KB's 3023607, 3035131 & 3031432. Kindly mark this as "Answer"
as I consider this matter resolved.
WOW, the enormous job is done!
The idea of a removal of KB2852386 was tested on a real hardware and works just fine although I guess it's a some kind of compromise solution but not the complete one, when at least in my case I don't have any problem with both also mentioned KB3035131 as
installed on Mar. 11, 2015 & KB3031432 as installed on Feb. 11, 2015 but solely that damn KB3023607 that is nothing more than some messy TSL security patch of Feb2015 that was cooked bad by MS from the very beginning!!!
http://www.infoworld.com/article/2884942/operating-systems/microsoft-posts-fixit-for-kb-3023607-the-poodle-patch-that-clobbers-cicso-s-anyconnect-vpn.html, which is always being removed by deepclean at the moment right after the install of the 2nd small parts
of the re-offered KB3021952 of Feb2015 & KB3032359 of Mar2015, those two are seeming to be just equal to installation of KB3023607 since this particular KB3023607 immediately appears in list of Installed Updates instead of the new entries of KB3021952 & KB3032359
as it should be logically.
I mean that it seems a culprit of all this March 2015 fuss is not a broken logic of KB2852386 as installed on Oct. 26, 2014 in my case and was working just nice before March 2015 but KB3023607 itself or some small part of it like a wrong/messy in-system
flag or marker, which prompts deepclean to remove it.
Anyhow I don't see any big difference if the 2nd small parts of the re-offered KB3021952 & KB3032359 are put to hidden list or it's KB2852386 as hidden. Moreover from my point it seems preferable to keep on Win7 deepclean function as KB2852386 installed
rather than KB3023607. Don't you think so?
Thanx
Rgds,
P.S. I believe this KB3023607 & deepclean mess-up does affect the most OR a lot of Win7 machines but it yet remains not widely known just since most of users don't burden themselves with deepclean. So I hope that some of MVPs, Patch Queens & Kings will finally
pay a bit of their f..king (guess what? right, good guess!) attention to this odd issue!
