KB3023607 repeatedly removed by deepclean after KB3032359/KB3021952 (5.2mb ea) repeatedly offered/installed...
2015-03-15T22:40:10+00:00
KB3021952 (Feb "Cumulative" Update for IE) invloves a "bundled" update, it includes KB3023607. KB3032359 (March "Cumulative" Update for IE) is "bundled" it includes KB3040335 & KB3023607 (Again???) KB3032359 (allegedly) supersedes KB3021952 but both are needed along with KB3023607 to have a fully patched system. The problem occurs when Windows Update Cleanup (deepclean) is run after all patches are installed, it removes KB3023607, the "bundled" update as superseded :
2015-03-12 09:31:26, Info CBS Adding: Package_for_KB3023607~31bf3856ad364e35~amd64~~6.1.1.0
2015-03-12 09:31:31, Info CBS DC: Package_for_KB3023607~31bf3856ad364e35~amd64~~6.1.1.0: unique components: 58 Size: 20.54 MB (21,538,670 bytes) 2015-03-12 09:31:31, Info CBS Total size of superseded packages: 20.54 MB (21,538,670 bytes)
The KB's 3021952 & 3032359 (5.2mb) that are continually removed/re-offered/re-installed/re-removed... lather, rinse, repeat... are actually the child package component KB3023607 which gets removed by deepclean.
Thread information Updated see my reply Pg 6 March 30 2:48 AM
Windows for home | Other | Windows update
2015-03-30T23:03:36+00:00
At this point, it's evident that MS needs to investigate why Windows Update cleanup detection logic is ...broken (for lack of a better word) on some user's computer's only, there has to be a "missing link" ... I'm out of ideas and don't see too many here or elsewhere on the Innernetz
I have 2 options to correct the problem of KB3031432 not appearing in Installed Updates but yet the MSU installer returns the message KB3031432 is already installed... and the PendingDeletes that won't.
  1. Repair Install
  2. Restore from prior backup image (2/12/15, after Feb Black Patch Tuesday, tested on spare HDD.
Thank to everyone who replied, and a special thanks to "J"... seems you're one of the few I've seen around here that "gets" it.
Regards & Hasta la Bye-Bye
"Pink"
Edit to add: I have successfully restored my system to a previous backup image (2/12/15) prior to the "March Patch Madness" described in my OP, uninstalled the troublesome KB2852386 that enables Update Cleanup and re-applied the March '15 patches, all now appear in Installed Updates, including KB's 3023607, 3035131 & 3031432. Kindly mark this as "Answer" as I consider this matter resolved... if only temporarily.
Thank you.
127 additional answers
    2015-03-25T20:11:01+00:00
    KB3021952 and KB3032359 should not re-offered if they are currently installed. An investigation is in-progress to find the cause and a resolution.
    In the meantime, if KB3021952 and/or KB3032359 are being repeatedly offered to you, search for installed updates following the instructions located here.
    Look for KB3032359, KB3021952, KB3046049. If they are present in the Update history list and the status for each shows Succeeded, you have received subsequent packages that supersede the ones being re-offered.
    You can hide the re-offered KBs.
    2015-03-25T21:58:09+00:00
    Look for KB3032395, KB3021952, KB3046049. If they are present in the Update history list and the status for each shows Succeeded, you have received subsequent packages that supersede the ones being re-offered.
    Thanks for the response, but this has been established. All of the above are confirmed installed in Installed Updates. I will hold off on running Windows Update Cleanup until a fix/resolution is found. The issue is Mr.Bear's mysterious "more important issues" & his (erroneous, it wold appear) assertion that "there's something very wrong with your Windows install" Re: KB3035131 (Kernel Update) not showing in Installed Updates/ also being falsely detected as superseded by WU Cleanup. The workaround I posted above (March 20, 6:01 PM) works for me, also contingent on NOT running WU Cleanup.
    As a matter of fact I'll go one further and un-install KB2852386 altogether and be rid of this albatross entirely.
    Kindly mark this as "Answer" if you would be so kind for as they say:
    I have nothing further to add to this discussion.
    BTW, the bolded text in your quoted reply contains a typo, s/b KB3032359 not 95.
    Regards
    Pink
    EDIT to add "installed in Installed Updates."
    2015-03-25T23:31:27+00:00
    Does it matter if KB3021952 and/or KB3032359 are listed in Update History but not in Installed Updates?
  4. Deleted
