Samsung Ativ Tab 3 power button not working, device battery always at 0%
2013-10-16T12:00:54+00:00
I am writing to you regarding a Samsung Ativ Tab 3 that I recently bought.
The item was purchased on 26-September-13, model no. is XE300TZC-K01AE. On 3-October-13 morning, I noticed that the screen was frozen and not unlocking when pressing the power button. After pressing the Windows button below the screen, the login screen came up and I was able to log in to Windows. On the home page, noticed that battery was at 0%, although there was about 45% charge around 7 hours back. I connected the charger, but the battery was drained by then and the device powered down. Though the charger was connected, the blue light was not on and also the device was not powering up. The charger was kept connected till 4 PM, but the device was still not powering up. After several calls and discussion with Samsung, the device was sent to a service center for repair and received on 10-Oct.
The device was working absolutely fine again, till yesterday evening. Again, the device froze and power key was not working and Windows button was used to unlock the screen after several attempts. Battery was showing 0% despite having 78% charge just fifteen minutes previously. On connecting the charger, battery charge was still at 0% but not increasing. Luckily this time the device did not shut down, but after 3 hrs of connecting the charger, battery has still been at 0%. I would like to know any suggestions to help solve this problem. I tried restarting the APC Battery Controller in Device Manager, but there was no improvement. I am also attaching results of the powercfg command.
Rgds,
Amrith
2014-04-18T05:59:50+00:00
2 days later....the solution seems to be to just keep it going & not plugged in til the battery empties (backing important stuff up meanwhile). From the fact that it took several days, I gather the "battery 0" warning is part of the misfunction. During this time you can sleep it manually w the "power off" control on the charms bar, being careful not to turn it off (cos then you wont know if the battery's emptied yet), and turn it on w the home key.
Once the battery is totally empty (no reponse of home key, little blue light by power button off), you plug it in and it works.
My guess is this explains what happened previously when I (& others I read) sent it for repair. By the time it got to the workshop the battery had emptied, so they plugged it in, found it worked, & returned it with a message like "you must have forgotten to charge it", missing the problem.
We'll see: if it's something that happens every few months, & is this easily solveable, it's not so bad. Particularly since one can still use it while waiting for the battery to empty.
Wonder if regularly letting the battery get to empty ever few months would prevent the phenomenon?
Be interested to hear what others found.
Rivka
46 additional answers
    2014-06-25T20:03:15+00:00
    Definitely suggest sending it in before warranty expires. You can send them my previous post. There seem to be a batch out there w a battery problem, and it can be fixed.
    Mine is fine since fixing
    2014-08-31T05:05:52+00:00
    I would like to thank you all for your. comments. I bought the ativ 3 tab and for 2 months it was fine and then the 0 battery charge incident happened. I even  took it to a Samsung tablet repair shop  and they told me that as it had Windows 8, it was not a tablet, it was a laptop and they couldn't fix it. Very helpful, I thought, another pr victory for Samsung. In desperation I started looking for a solution on line. I read many, hold this button down for 30 seconds etc, none of them worked for me. Then I came across this page, drained the charge and now it's working finer, for how long, I don't know. I do have some confidence that if the problem reoccurs, I well know what to.do.
    One additional point that may or may not be of any use to you. When my tab would not turn on, I put my Wife's kindle charger into the top portal and the lights came on straight away. Don't do this while your tab charger is plugged in, as soon as the power lights come on unplug the kindle charger.
    Thanks again.
    Jim
    2014-09-03T16:49:12+00:00
    That's exactly what I do when mine acts up; borrow my mom's nook charger. When the lights come on and I quickly put on a long movie. After the battery dies, I charge it (it charges up pretty quickly, which is nice). Then no issue.
    2014-09-09T18:51:38+00:00
    I have the same problem. What did you do to solve?
    regards,
    Jader.
