Samsung Ativ Tab 3 power button not working, device battery always at 0%
2013-10-16T12:00:54+00:00
I am writing to you regarding a Samsung Ativ Tab 3 that I recently bought.
The item was purchased on 26-September-13, model no. is XE300TZC-K01AE. On 3-October-13 morning, I noticed that the screen was frozen and not unlocking when pressing the power button. After pressing the Windows button below the screen, the login screen came up and I was able to log in to Windows. On the home page, noticed that battery was at 0%, although there was about 45% charge around 7 hours back. I connected the charger, but the battery was drained by then and the device powered down. Though the charger was connected, the blue light was not on and also the device was not powering up. The charger was kept connected till 4 PM, but the device was still not powering up. After several calls and discussion with Samsung, the device was sent to a service center for repair and received on 10-Oct.
The device was working absolutely fine again, till yesterday evening. Again, the device froze and power key was not working and Windows button was used to unlock the screen after several attempts. Battery was showing 0% despite having 78% charge just fifteen minutes previously. On connecting the charger, battery charge was still at 0% but not increasing. Luckily this time the device did not shut down, but after 3 hrs of connecting the charger, battery has still been at 0%. I would like to know any suggestions to help solve this problem. I tried restarting the APC Battery Controller in Device Manager, but there was no improvement. I am also attaching results of the powercfg command.
Rgds,
Amrith
2014-04-18T05:59:50+00:00
2 days later....the solution seems to be to just keep it going & not plugged in til the battery empties (backing important stuff up meanwhile). From the fact that it took several days, I gather the "battery 0" warning is part of the misfunction. During this time you can sleep it manually w the "power off" control on the charms bar, being careful not to turn it off (cos then you wont know if the battery's emptied yet), and turn it on w the home key.
Once the battery is totally empty (no reponse of home key, little blue light by power button off), you plug it in and it works.
My guess is this explains what happened previously when I (& others I read) sent it for repair. By the time it got to the workshop the battery had emptied, so they plugged it in, found it worked, & returned it with a message like "you must have forgotten to charge it", missing the problem.
We'll see: if it's something that happens every few months, & is this easily solveable, it's not so bad. Particularly since one can still use it while waiting for the battery to empty.
Wonder if regularly letting the battery get to empty ever few months would prevent the phenomenon?
Be interested to hear what others found.
Rivka
46 additional answers
    2014-10-30T11:33:12+00:00
    Just came back from the lab a 3rd time, and guess what: "we didn't find any problem; your computer works fine".
    This is more than frustrating. Trying to get the head of BUG again to see what happened to the supposed instructions to correct the problem even if they can't see it.
    To me it seems clear the solution is to replace it, but somehow noone seems to care they're selling a flawed product.
    Any idea of who can give the problem some publicity?
    2015-02-28T03:54:07+00:00
    Hi im forma México i have the same issue in my samsung ativ 3, after 2 months of using it the battery does not work and i can,t use it for 10 days and after this period of days when i plug it the battery works again, how can i fix this? Thank you
    2015-03-01T10:27:57+00:00
    Hi All
    I am also a great fan of Ativ Tab 3, bought it 1.5 years ago in Germany.
    Few times I had surprises: power button was not waking up the device, no power light, could not switch on the device, 0% of charging, etc.
    Definitely something wrong with power management. My workaround - unplug the battery and plug it back. No more problems many months!
    Open a back cover using any plastic card, locate the big connector in the center below camera, unplug it putting a tooth stick behind it, then in a few seconds plug it back. Viola!
    But note! Blackout can happen suddenly, always have a card and stick with you. Just in case :)
    Regards,
    Mikhail
    2015-03-02T02:26:58+00:00
    Thank youuuuu Mike, that really worked!!!!!!!!!!! Because of all of you i think i got the protocol that we have to follow in orden to revive our tablet
    1.- it seems to me when you put your tablet in sleep mode for long time (i mean several hours) something happens with the battery or the system that makes the problem,  so, don,t put the tablet in sleep mode, it,d be better to turn it off. (anyways i noticed a lot of people don,t put their tablet in sleep mode but what happens is that the power button is very sensitive and when you,re carring it everywhere simething touches the button and the problem appears,so, get a cover that can really protect this button or modify this one so you only can turn the system on til you press the button after several seconds or something like that or don,t carry it everywhere.
    2.- to make it work if the blackout is already in the ativ 3 is unplug the battery for several seconds (i mean, once you open up the tablet) plug it again and that,s it
