Missing Network Settings - "Find Devices and Content"
2013-11-29T13:30:12+00:00
Windows 8.1 -Under all my various network adapters there is no  "Find Devices and Content" box.
I've tried various fixes. Changing homegroup etc. Nothing work.
Please provide some guidance
2014-01-11T17:54:45+00:00
I am not sure if everyone is checking at the right place if they are connected to domain network and they have 8.1 because only 8.1 has this option. Windows 8 has a different way to share devices and content.
For chromecast troubleshooting:
https://support.google.com/chromecast/troubleshooter/2995236?hl=en&ref\_topic=3447927#ts=3081637,3249450
Where to find the option to share:
http://windows.microsoft.com/en-us/windows-8/turn-sharing-on-or-off
I have been using Windows since forever and have used Apple too, so switching to Mac / Apple is not going to help. Its just another OS with the same fundamentals. Go figure it out in a Apple store if you want a demo.
110 additional answers
    2014-01-17T21:05:05+00:00
    Hi, thanks for the tip, that was the first thing I tried, I simply disabled my firewall, even so, no option to share nothing, and no joy in trying to access anything.
    Let's keep pushing, sometime they'll get annoyed with us and look at the problem.
    Best regards.
    2014-01-20T01:12:00+00:00
    I thought I'd pass this on. One of the earlier messages in this thread gave me a tip on where to look.
    My problem was not quite the same, but had a similar effect. I had a W8.1 laptop networked to several other machines (W7 and XPs). I moved it to another network (for business reasons) for several days and when I tried to come back to the original workgroup, I found no settings changed BUT I couldn't connect to the other computers. "Entire Network" was not available, and the machine couldn't find the workgroup. All of the other computers could connect to each other, of course, but not to the 8.1 machine.
    So I checked Windows Firewall and it was turned off (I use Comodo, which I had also turned off). But I went into the "Advanced Security" setting and found ALL the settings in the Group "Network Discovery" NOT "enabled". So I enabled all of them, and voila!
    • my network came back. And all this with Windows Firewall TURNED OFF!
    I've attached a screenshot to show what all these settings are. I did disable the UPnP-In rules that were not private, and I'm wondering about some of the other "public" rules, and whether or not they should be enabled. But I'll go with this for now, and I'm going to keep looking to see if I can get everything back again. At least I can communicate with the other computers on the network now.
    Just changing the "Inbound Rules" worked for me, but I changed the appropriate "Outbound Rules" for good measure.
    I still haven't figured out how to get my "Entire Network" and workgroup icons back in the Network window yet.
    2014-01-20T07:24:14+00:00
    I hit the same issue and here is my solution:
    1. launch "Hyper-V Manager"
    2. in the menu go to Action->"Virtual Switch Manager"
    3. remove all entries under "Virtual Switches". (these are 3 virtual switches in my computer: Windows Phone Emulator, 802.11n Wireless LAN card, and Realtek PCIe GBE family controller)
    Now go back to check if "Find device and content" shows up
    Good luck!
    PS. if you are using Hyper-V, remember to add those virtual switches back. Otherwise your VM won't have network connection.
    2014-01-21T03:59:05+00:00
    i finally found the solution
    goto Control Panel\All Control Panel Items\Troubleshooting\Network and Internet
    and select homegroup , then skip network troubleshoot and it will ask that changing to private network will solve and apply the fix :)
