Missing Network Settings - "Find Devices and Content"
2013-11-29T13:30:12+00:00
Windows 8.1 -Under all my various network adapters there is no  "Find Devices and Content" box.
I've tried various fixes. Changing homegroup etc. Nothing work.
Please provide some guidance
2014-01-11T17:54:45+00:00
I am not sure if everyone is checking at the right place if they are connected to domain network and they have 8.1 because only 8.1 has this option. Windows 8 has a different way to share devices and content.
For chromecast troubleshooting:
https://support.google.com/chromecast/troubleshooter/2995236?hl=en&ref\_topic=3447927#ts=3081637,3249450
Where to find the option to share:
http://windows.microsoft.com/en-us/windows-8/turn-sharing-on-or-off
I have been using Windows since forever and have used Apple too, so switching to Mac / Apple is not going to help. Its just another OS with the same fundamentals. Go figure it out in a Apple store if you want a demo.
110 additional answers
    2015-08-19T03:38:19+00:00
    WORKED FOR ME
    I read through 9 pages of comments, like others.  What a broad selection of non-helpful suggestions.
    The fix for me was to go to user accounts in control panel. Then select Change UAC settings, next move the slider down to the second notch from the top, then "OK".
    Go to PC Settings, Network, Connections.  Select your connection. Amazingly, the FDandC slider is now visible.  Turn on.
    Now go to Network and Sharing Center. I see under "View your active networks" that my network is marked "Private"
    Also, in NandSC I can select "Change advanced sharing settings" and it shows the current profile is Private and I can edit settings for profile types.
    This, on the face of it, implies that the problem of the "missing FDandC slider" is fixed for me.
    For fun, I can go back to UAC and set highest level. Then, go to PC Settings, Network, Connections.  Select your connection.  Wow, the Slider is missing again.
    I can adjust the UAC back down again and the Slider re-appears.
    I have no idea how this works. I can see no reason for a correlation between UAC level and the slider appearing and disappearing. But it does exist (but only on certain systems). I will qualify the statement by saying that this correlation must only exist on Win 8.1 systems that have the "disappearing FDandC slider" issue. The specific PC I am working on now is the first that I have seen with this issue.
    On all other PCs that I have worked on, you simply go to the network connection and move the slider to change the profile type (as suggested by several good-intentioned posters) If you have not personally experienced this you probably believe the various previous posters are stupid not to just move the slider. For the previous posters part, (and mine as well) We think the various responders are dumb as a sack of hammers to not see that people are screaming "but the problem is that the SLIDER IS NOT THERE!" Many responders did not read the statement "the Slider is not there".
    Making the Slider disappear and reappear is a reproducible condition, but (in my experience) only on the few PCs that have been affected by the "disappearing slider issue".  This set of PCs is at least big enough to support this long-running thread, as well as others on different blogs. The "adjust the UAC solution" may only work for a subset of the "disappearing slider issue" set. As I said, this PC is the first I have ever seen with this problem.
    Until some smart person can figure out what causes the "disappearing slider issue" in the first place, there will not/cannot be not response from Microsoft.  They must see a PC, with this issue, with their own eyes. The occurrence of this issue is rare enough that this may not happen soon, if ever.
    I feel sorry for those who have wiped their PCs, moved their profiles, or performed other radical procedures suggested in the previous nine pages.
    Even though I have had the experience outlined above and was able to apply the fix suggested by the poster to fix the issue, this is work around at best.  It requires that you reduce your UAC security level to work around the issue. I can bear it, but some won't.
    It is clear to me that the problem is real, if only for a small set of affected users. We may never know.
    It is kind of creepy that the poster above suggested that this has been seen with Win 10 too.
    Goodnight, and Good Luck.
    2015-08-19T04:08:12+00:00
    I have three windows 8.1 computers, one of them has this issue.  Tried the UAC slider with no luck (mine was already one from the top).  I've sense given up on the problem.  Just hope it doesn't become an issue on my new 10 build
    2015-08-19T04:38:39+00:00
    I feel your pain.  I suspected that this solution is not for everyone.  A poster above had a registry hack solution, but me and at least one other responder couldn't find the key that was supposed to be removed. So, the "disappearing slider problem" can apparently have more than one solution, and, the solutions don't work universally. It's another clue for the smart person that, hopefully, will resolve the issue. Thanks for your response. At least I'm not the only one fighting this issue.  Good luck.
    2015-10-11T00:23:30+00:00
    I'm sorry many of you are having problems with HomeGroup!
    I have the same problem, but not with exactly the same variables:
    • I'm on a Home LAN with a Gateway for internet and video services.
    • I want to work file and printer sharing with Win 8.1s, Win 7s and XPs (Maybe Win10s)
      • Therefore, I used a Workgroup as my local networking sharing model on the home LAN.
      • Workgroup used to work so well, even though I had some sharing protocol security concerns.
        • My desired protocol improvement work effort never happened because I added a Win 8.1 to replace a damaged Win XP machine that would have cost more to repair than to replace.
        • Because of my backup processes my wife didn't loose any of her "really important stuff" (lucky me).
        • Unfortunately, I did give up on the 8.1 issue that evolved and bought a temporary high maintenance backup drive as a direct connect for the Win 8.1 due to unresolved one way connectivity being a problem for such a long time and the new machine is a Laptop.
    LAN connectivity:
    • Win7 and Win XPs are wired
    • Win 8.1 is wireless
    • Win 7 can "see" and access Win 8.1
    • Win 8.1 can "see" and can't access Win 7 due to "permission issues" (original target for backup functions due to available processing power and ability to operate with older and newer sharing protocols).
      • This is where I ran into the Missing Network Settings - "Find Devices and Content" object not being presented in the heavily published setup sequences for Win 8.1. and why I came to this page.
      • I don't like the idea of using a Win XP as a backup server at the lower protocol security levels, but I started doing it anyway for less work through automation.
    • Win XP can "see" and access Win 8.1
    • Win 8.1 can "see" and access Win XP
    • Win XP can "see" and access Win 7
    • Win 7 can "see" and access Win XP
    Workgroup:
    I have spent hours setting up Workgroup in the beginning getting it to work (Win98SE).
    • Then hours again when I added a new OSs to the mix, because for some reason the user interfaces we were used to and spent so much time learning how they really worked became harder to find or understand.
    • Win7 was another toughy.
    • Win 8.1 seemed to come up right away.
    But, once you get a local area network sharing system working and you have created the functionality you want, it can break (there are a few reasons this can happen).  Restoring functionality is a system restore (system restores have a limited window of opportunity when you are really to busy to identify subtle changes) or manual resetting requiring a different set up list by OS version to restore connectivity with a restart.
    Now with Win 8.1 I'm having problems getting the current issue (above) un-broke!    I have spent a lot of time on and off looking though all kinds of recommendations to try as long as I don't hack the registry or start changing a lot of services or security settings as a work around (all of those things should be set correctly using the available user interfaces - if not we need to tell them).  Like this,  ***THE USER INTERFACES PROVIDED IN WIN 8.1 ARE CONFUSING BASED ON HISTORICAL INTERFACE USE CONDITIONING AND ARE THEREFORE COUNTER INTUITIVE BASED ON MY YEARS OF EXPERIENCES***
    I have ended up checking all kinds of stuff that is supposed to be turned on only to find it is turned on.  I'ts getting harder and harder to understand how this stuff works because of exponential levels of complexity due to increased numbers of variables, which creates a curve of diminishing returns for trouble shooters.
    Here is the best effort I have found so far on Microsoft's behalf addressing LAN sharing connectivity (http://windows.microsoft.com/en-us/windows/sharing-files-printers-help#sharing-files-and-printers=windows-81&v1h=win81tab6&v2h=win7tab2&v3h=winvistatab1&v4h=winxptab2
    • you can switch between OSs at the top of the page, pretty cool concept).
    But, I don't want to be told how to fix it any more, I want an APP!
    Let me download an MS APP, let me make simple common sense choices based on what I am trying to achieve (homegroup, workgroup, VPN, etc.)  and fix it!  Get everything back online and move on.  Fixing all the variables now needs to be automated.
    My Most Recent Experience:
    Let me suggest a thought, which has been occurring to me because I got one way connectivity on a XP within the last week. The connectivity issue is kind of like the Win 8.1.  The machines in the LAN can "see" the XP but they can't access it and I now have it isolated and booting on a CD because it has a rootkit (the cat6 cable is unplugged a lot)!
    I am running a series of anti-malware scanners as full scans on all the machines on my network till I am decided they are clean for now (just have someone click on the wrong website and that can change).
    I'm struggling with the rookit identified PC, because the tools aren't taking it out on the first pass like they used to. I'm using all kinds of ant-malware to try and remove it.   I'm contemplating formatting the OS and reinstalling. Probably a WIN7 if I can find it out there.
    My thoughts are (just call me paranoid):
    • One of the first things malware wants to do is take out connectivity "to" the PC, so that I can't get the latest versions and database updates to go after the causes and caused problems at the ram and file level.
      • I store clean copies of anti-malware on other PCs in the LAN
    • The second thing malware would like to do is to spread itself in the LAN once it got a foot hold through network shares.
    • These things could be achieved by messing with the many OS variables that make network sharing function.
      • You then would have the task of finding the specific "switches" before the infection spreads and the LAN administrator!
        • Looks like your chances are pretty slim!
    • My thinking is these are the two first symptoms you will see in a more advance malware setup if it gets established stealthy and wants to get into stealing data, key loggers or other system take over features.  Not the traditional malware terrorism (wipe your hard drive), but the steal you blind stuff.
    Closing Thoughts For Now:
    I want to stick to this tread of getting back network sharing connectivity, but, this information may be helpful to others based on my current paranoid state:
    • Malware Bytes has identified stuff and is having problems removing what it finds.  Probably, is leaving behind the cause.
    • Microsoft  Safety Scanner is find more than other, but is also apparently not removing the cause.
    I have two PCs I was thinking about taking to free WIN 10 upgrades and haven't had to time to look at the possibilities!
    Earnesto
