Missing Network Settings - "Find Devices and Content"
2013-11-29T13:30:12+00:00
Windows 8.1 -Under all my various network adapters there is no  "Find Devices and Content" box.
I've tried various fixes. Changing homegroup etc. Nothing work.
Please provide some guidance
2014-01-11T17:54:45+00:00
I am not sure if everyone is checking at the right place if they are connected to domain network and they have 8.1 because only 8.1 has this option. Windows 8 has a different way to share devices and content.
For chromecast troubleshooting:
https://support.google.com/chromecast/troubleshooter/2995236?hl=en&ref\_topic=3447927#ts=3081637,3249450
Where to find the option to share:
http://windows.microsoft.com/en-us/windows-8/turn-sharing-on-or-off
I have been using Windows since forever and have used Apple too, so switching to Mac / Apple is not going to help. Its just another OS with the same fundamentals. Go figure it out in a Apple store if you want a demo.
110 additional answers
    2015-03-10T16:22:40+00:00
    This solution worked for me! Thank you. What a pain in the ***!
    2015-03-14T01:42:42+00:00
    Hey guys,
    Great news, I found a fix! I realized another problem was related to the problem we all have, and that is that the network location actually doesn't show up at all. So I searched for a solution to that problem, and I found this page: https://technet.microsoft.com/en-us/library/gg252535(v=ws.10).aspx
    The solution is this: remove HKCU\Software\Microsoft\Windows NT\CurrentVersion\Network\NwCategoryWizard
    The end. Slider is back! :)
    Rather that deleting it I just set the value from 0 to 1. I killed and restarted explorer.exe via TaskMgr to reload the registry and ta-da - the setting was back.
    THANK YOU for your post. I was going insane trying to get this setting to show up so I could get my ChromeCast to work.
    Yes, I know OP doesn't have a ChromeCast but maybe your reghack or mine will help.
    2015-04-04T17:31:35+00:00
    i finally found the solution
    goto Control Panel\All Control Panel Items\Troubleshooting\Network and Internet
    and select homegroup , then skip network troubleshoot and it will ask that changing to private network will solve and apply the fix :)
    This is what I had to do to "WORK AROUND", I cannot stress that enough, the problem. This is a stupid fix and the "find devices and content" is still not found.
    I've checked...
    PC Settings > Network > Connections > Network Device > Nothing here.
    PC Settings > Network > HomeGroup > Tells me to go to "Network > Connections > Network Device".
    Charms > Right Click Wifi Name > no option to turn on sharing.
    My System
    I am not part of a Domain
    I am not part of a Home Group
    I am running Windows 8.1 latest updates (SPRO3)
    I have Turned UAC down 1 tick
    I have deleted the Hyper-V virtual switch networks
    I have uninstalled Hyper-V
    I have tried turning it off and on again
    My Wifi device is not bridged
    How do we get the option "find devices and content" back?
    2015-04-16T12:29:35+00:00
    Hey guys,
    This solution worked for me so thanks dear users - Um Microsoft support, a bit embarrassing that you couldn't answer this question on page 1 all those years ago but the users of the software you created come up with the answer; Wow! Also Microsoft still have not fixed this problem through an update and generally waste massive amounts of time for users trying to resolve this and other annoying windows issues.
