Error Code 0xc0000017, There isn't enough memory available to create a ramdisk device
2013-10-17T21:57:10+00:00
I'm getting this blue screen message when Windows 8.1 finishes downloading and I reboot my computer as instructed:
Recovery
Your PC needs to be repaired
Error Code: 0xc0000017
You'll need to use the recovery tools on your installation media
However, after getting that message, I'm able to select F9 and it reboots back into Windows 8 with a message stating:
Sorry, we couldn't complete the update to Windows 8.1. We've restored your previous version of Windows to this PC
0xC1900101-0x20017
Anybody have insight with what's going on and how I can fix it?
I have 8 GB of RAM, plenty of hard drive storage, and my computer exceeds all the OS requirements, I 've been running Windows 8 great for about a year.
Windows for home | Previous Windows versions | Install and upgrade
2016-12-10T00:45:18+00:00
Ladies & Gentlemen,
I came across the issue of BSoD code 0x0000017 during a recent upgrade to a Windows 10 Insider Preview build, when I was asked to look at a friend's desktop when she suffered this BSoD code.
There are a few solution that have been batted around, and I have no doubt that they have worked for the person who has posted the solution.
  • unplugging all USB devices certainly reduced the memory allocation for the drivers - if the device is not running then it does not need memory allocation
  • stopping your anti-virus - this will certainly stop any false positives, especially where there are major alterations to the operating system .. we have witnessed this issue perviously during the installation of service packs
The BSoD error code 0x0000017 appears to be associated with "Bad Memory". I have witnessed this error code with systems that are running both x86 & x64 systems, with 4Gb, 8Gb & 12Gb. I am unable to explain the reason why. However, the solution that I use is something that I was taught in the days of Windows 2000 to Windows XP & server 2003.
  • Open a Command Prompt with Administrative Privelages
  • Type "BCDEdit /Enum" & press Return, or Enter - without quotations
  • Download the update .. & before you restart go to the next step
  • Type "BCDEdit /DeleteValue {BadMemory} BadMemoryList" & press Return, or Enter - without quotations
Hopefully this will give you the solution the the issue that you are experiencing
Arthur
44 additional answers
    2013-10-18T07:02:47+00:00
    Same problem here, too.
    I also cleared the cache on the store, it didn't help.
    What is a ramdisk device exactly?
    2013-10-18T10:03:25+00:00
    Im having exactly the same problems. I have tried loading this large download SIX times!! each taking several hours to do, each time with the same 0xc0000017 error message.
    I too have been running Windows 8 just fine for some time, so why the problem?
    I notice that the suggested "fix" includes disabling USB devices, printers etc, which is exactly the OPPOSITE of the recommendation on the upgrade pages.
    Can someone PLEASE help....???
    2013-10-18T12:36:57+00:00
    I am having the same issue upgrading from the 8.1 Preview to 8.1 Final.
    2013-10-18T15:10:16+00:00
    Same problem, seems many others are finding they cannot upgrade either.
