Error Code 0xc0000017, There isn't enough memory available to create a ramdisk device
2013-10-17T21:57:10+00:00
I'm getting this blue screen message when Windows 8.1 finishes downloading and I reboot my computer as instructed:
Recovery
Your PC needs to be repaired
Error Code: 0xc0000017
You'll need to use the recovery tools on your installation media
However, after getting that message, I'm able to select F9 and it reboots back into Windows 8 with a message stating:
Sorry, we couldn't complete the update to Windows 8.1. We've restored your previous version of Windows to this PC
0xC1900101-0x20017
Anybody have insight with what's going on and how I can fix it?
I have 8 GB of RAM, plenty of hard drive storage, and my computer exceeds all the OS requirements, I 've been running Windows 8 great for about a year.
Windows for home | Previous Windows versions | Install and upgrade
2016-12-10T00:45:18+00:00
Ladies & Gentlemen,
I came across the issue of BSoD code 0x0000017 during a recent upgrade to a Windows 10 Insider Preview build, when I was asked to look at a friend's desktop when she suffered this BSoD code.
There are a few solution that have been batted around, and I have no doubt that they have worked for the person who has posted the solution.
  • unplugging all USB devices certainly reduced the memory allocation for the drivers - if the device is not running then it does not need memory allocation
  • stopping your anti-virus - this will certainly stop any false positives, especially where there are major alterations to the operating system .. we have witnessed this issue perviously during the installation of service packs
The BSoD error code 0x0000017 appears to be associated with "Bad Memory". I have witnessed this error code with systems that are running both x86 & x64 systems, with 4Gb, 8Gb & 12Gb. I am unable to explain the reason why. However, the solution that I use is something that I was taught in the days of Windows 2000 to Windows XP & server 2003.
  • Open a Command Prompt with Administrative Privelages
  • Type "BCDEdit /Enum" & press Return, or Enter - without quotations
  • Download the update .. & before you restart go to the next step
  • Type "BCDEdit /DeleteValue {BadMemory} BadMemoryList" & press Return, or Enter - without quotations
Hopefully this will give you the solution the the issue that you are experiencing
Arthur
44 additional answers
    2013-10-18T03:51:37+00:00
    I'm having the exact same issue. I have 4GB of ram and the bios sees it all just fine.
    2013-10-18T04:43:07+00:00
    Hi Ebhanson,
    I can imagine the inconvenience you have experienced.
    Do you have Webroot Antivirus software installed on the computer?
    Here are a few methods which you can follow to resolve the issue:
    Method 1:
    Temporarily disconnect all the external devices (except mouse and keyboard) connected to the computer and then try to install Windows 8.1.
    Method 2:
    If the issue persists, I would suggest you to uninstall Antivirus software and then try to upgrade to Windows 8.1.
    Note:
    1. Please make sure to re-install Antivirus software after upgrading to Windows 8.1.
    2. Antivirus software can help protect your computer against viruses and other security threats. In most cases, you shouldn't disable or uninstall your antivirus software. If you have to temporarily disable or uninstall it to install other software, you should re-enable it as soon as you're done. If you're connected to the Internet or a network while your antivirus software is disabled or uninstalled, your computer is vulnerable to attacks.
    Note: Please check the private message also.
    Hope this helps. If you have any further queries/issues related to Windows, write to us and we will be glad to assist you further.
    2013-10-18T05:24:28+00:00
    What would AV software have to do with this? The blue screen doesn't happen in Windows. It happens after the reboot during the install process ... AV isn't running at that point because Windows isn't running.
    2013-10-18T06:53:56+00:00
    Thanks for the reply, unfortunately neither method worked. I'm still getting the same error message on reboot. I'll upload my computer logs to the private message.
