Dell Venue Pro loses wireless connection after installing Windows Updates
2013-12-12T02:08:43+00:00
The Dell Venue 8 Pro and Dell Venue 11 Pro lost all wireless connectivity after installing either Windows Update**KB 2887595** or**KB 2903939**.
How can I get my WiFi back?
2013-12-12T02:09:53+00:00
This issue may occur if specific Windows Updates are not installed in the proper order. Microsoft has made a change to prevent further customers from getting into this state.  Customers must now have a pre-requisite update (KB 2883200) installed before being offered these updates.
To restore wireless connectivity:
1.     Uninstall all of the following updates:
·         KB 2887595 – Windows RT 8.1, Windows 8.1, and Windows Server 2012 R2 update rollup: November 2013
·         KB 2903939 – Windows RT 8.1, Windows 8.1, and Windows Server 2012 R2 update rollup: December 2013
To uninstall an update, go to the Control Panel and select Programs.  Then, under Programs and Features, select View installed updates.  Select the updates listed above and click Uninstall.  If you’re prompted for an administrator password or confirmation, type the password or provide confirmation.
2.     Install the updates listed below.  When you run Windows Update, the updates will now automatically be installed in the proper order.  You must restart the computer after you apply each update.
·        Install KB 2883200
·        Install KB 2887595 and KB 2903939.
133 additional answers
    2016-01-18T20:38:47+00:00
    Working backup of or on this tablet?
    I've used Macrium Plus to make useable backups that can be moved to a different system, which appears to be the most reliable way to resolve the issues and get back to work.
    2016-01-18T21:36:27+00:00
    Following the instructions on tabletpcreview? Or did you just use Macrium to create an ISO backup you could load up later from an external drive?
    2016-01-21T01:11:52+00:00
    I just used Macrium to create an ISO. I haven't tried the factory reset.
    2016-03-29T12:57:53+00:00
    Hi
    I have a Dell 5130 Venue 11 pro. The Issue exist only with my own router from D-Link DIR-855. A alternative old AP from Pheenet (WAP-554G) and the TP Link at Work nothing incidents on the Wifi Adapter. All other Clients on my home have nothing Problems.  And the Venue with other Wifi Adapter(USB) works fine.
    Result: The onboard Wifi Device or the Driver receives Networkpackages and take crashes.
    I hope this help to Bypass the issue or visible inkompabilities between some Brands and their products.
    Kind regards
    e
