Dell Venue Pro loses wireless connection after installing Windows Updates
2013-12-12T02:08:43+00:00
The Dell Venue 8 Pro and Dell Venue 11 Pro lost all wireless connectivity after installing either Windows Update**KB 2887595** or**KB 2903939**.
How can I get my WiFi back?
2013-12-12T02:09:53+00:00
This issue may occur if specific Windows Updates are not installed in the proper order. Microsoft has made a change to prevent further customers from getting into this state.  Customers must now have a pre-requisite update (KB 2883200) installed before being offered these updates.
To restore wireless connectivity:
1.     Uninstall all of the following updates:
·         KB 2887595 – Windows RT 8.1, Windows 8.1, and Windows Server 2012 R2 update rollup: November 2013
·         KB 2903939 – Windows RT 8.1, Windows 8.1, and Windows Server 2012 R2 update rollup: December 2013
To uninstall an update, go to the Control Panel and select Programs.  Then, under Programs and Features, select View installed updates.  Select the updates listed above and click Uninstall.  If you’re prompted for an administrator password or confirmation, type the password or provide confirmation.
2.     Install the updates listed below.  When you run Windows Update, the updates will now automatically be installed in the proper order.  You must restart the computer after you apply each update.
·        Install KB 2883200
·        Install KB 2887595 and KB 2903939.
133 additional answers
    2014-06-06T06:24:12+00:00
    Hello John,
    Thank you for your response.
    I would suggest you to manually download the latest definitions for Windows defender and check if it helps.
    Refer this article:
    How to manually download the latest definition updates for Windows Defender
    http://support.microsoft.com/kb/923159
    Please reply with results so that we can assist you further.
    Thank you
    2014-07-12T14:06:41+00:00
    Dell has published both bios update and WiFi/BT drivers.  So far so good.  I am surprised Dell took so long.  I have not  done any work arounds nor stopped updates, just uninstalled/reinstalled the WiFi card with success after letting DV8P go to "sleep".
    2014-07-12T15:22:18+00:00
    Thanks for the update, will give the new packages a go.
    2014-07-13T20:10:30+00:00
    I just did a complete reinstall of Win8.1 and updated all the drivers and BIOS at Dell before I did a Windows update. Many times before I had lost WIFI doing this so I crossed my fingers and did the Windows update and haven't had a problem with the WIFI at all so far. So it seems and I hope Dell fixed the WIFI problem.
