Dell Venue Pro loses wireless connection after installing Windows Updates
2013-12-12T02:08:43+00:00
The Dell Venue 8 Pro and Dell Venue 11 Pro lost all wireless connectivity after installing either Windows Update**KB 2887595** or**KB 2903939**.
How can I get my WiFi back?
2013-12-12T02:09:53+00:00
This issue may occur if specific Windows Updates are not installed in the proper order. Microsoft has made a change to prevent further customers from getting into this state.  Customers must now have a pre-requisite update (KB 2883200) installed before being offered these updates.
To restore wireless connectivity:
1.     Uninstall all of the following updates:
·         KB 2887595 – Windows RT 8.1, Windows 8.1, and Windows Server 2012 R2 update rollup: November 2013
·         KB 2903939 – Windows RT 8.1, Windows 8.1, and Windows Server 2012 R2 update rollup: December 2013
To uninstall an update, go to the Control Panel and select Programs.  Then, under Programs and Features, select View installed updates.  Select the updates listed above and click Uninstall.  If you’re prompted for an administrator password or confirmation, type the password or provide confirmation.
2.     Install the updates listed below.  When you run Windows Update, the updates will now automatically be installed in the proper order.  You must restart the computer after you apply each update.
·        Install KB 2883200
·        Install KB 2887595 and KB 2903939.
133 additional answers
    2014-03-08T20:59:02+00:00
    I spoke too soon, back to its same problems.  I really wanted to like this DV8P (and Windows 8 tablets), and do otherwise, but it is really useless if it can't reliably stay connected to the internet.  Ridiculous.
    2014-03-08T21:03:35+00:00
    First go to Change Windows update Settings and select "Check for updates but let me choose when to download them" From the left hand side click of the update panel click on "View Update History" from there click on to remove an update see "Installed Updates". Once there find the bad updates and right click and   uninstall those 3 updates: KB 2883200  KB 2887595 and KB 2903939.
    Then restart you system and go to Windows Update and click on "check for updates" after it is complete you will see 3 important updates is available, click on that. Right click on one of them and a drop down menu will appear with copy details and Hide Update... Click on HIDE UPDATE! Then do this to the other 2 bad boys...
    Hope this helps you :)
    2014-03-08T21:06:35+00:00
    Please read my post and uninstall those bad update and hide them from ever being updated again!
    2014-03-09T04:13:27+00:00
    Gosh... stop with this "uninstall update x, y z" nonsense already. Dammit. If you want a working device reset Windows and install it again, <with all Windows updates>, and it will work. Hiding and uninstalling update x. y, z is so bad and wont help you really anything and just break your system over time.
    However, this wont change anything about that
    1.) the device (the build in wifi card) cant handle N connections.
    2.) it cant handle Bluetooth.
    Both results in the device becoming unstable and also wifi to break down. Sadly being said this wont ever be fixed and it was the last device I bought from Dell.
