Nokia 206 - disk space problems
2013-11-17T18:48:17+00:00
I have a Nokia 206 dual sim phone, and it has a lot of DEMO games pre-installed. These are listed as System Files and i cannot get to remove them. Due to this, i am running very low on operational disk space, even after installing an external memory card.
How can i get rid of all the apps that are pre-installed and of no use to me, especially the DEMO games.
Please advice.
    2015-08-15T02:55:11+00:00
    Gotcha .. I find it how To delete apps
    and demo games in nokia 206. It is working.
    First
    of all you need
    to create a
    backup file, goto
    settings>sync &
    backup>create
    backup>mark
    appsandgames
    press done.
    Now open
    BlueFTP App
    goto memory
    card>backup
    files folder there
    you’ll see
    backup000.nbf
    rename it as
    ‘backup000.nbf.zip’
    now open it and
    goto
    predefjava>predefgames and
    there you’ll see
    folders named
    Such as
    'BlockBreaker3Unlimited_SMS_Nokia_Asha_206_DS_EN_FR_DE_IT_ES_TC_IGP_NOVI_100_private' (if you want to delete block breaker) this is the actual
    file name of
    block breaker 3 unlimited app
    now write
    down all the
    folder names
    which has
    ‘_private’
    suffixed to their
    names,(you have write on paper cause u need to them later to change the names of any to images files) now
    close the backup
    file. Copy 2
    image files(any images better use less kb images) to sd
    card (if u have images dnt need to copy extra)and
    rename 1 file as
    without ‘.jpg’
    and close
    BlueFTP App and
    goto
    menu>apps>sd
    card and
    rename other image file such as
    BlockBreaker3Unlimited_SMS_Nokia_Asha_206_DS_EN_FR_DE_IT_ES_TC_IGP_NOVI_100.jar
    file by adding
    ‘.jar’ extension
    and mark both
    files and move
    to games
    folder of mobile you ‘ll be
    notified as 1 file
    name already
    exist, now goto
    games and
    highlight Block breaker 3 app
    press options
    and delete. Its truly working.:-) and delete other apps with same procedure
    I create backup then open blue ftp  and rename file from backup000.NBF to 'backup.NBF.zip' but there is not comming predefjava. Tell me what mistake i have done?
    2015-08-15T10:56:47+00:00
    Did you unpack that NBF file which is a ZIP file actually?
    2015-08-18T03:34:08+00:00
    How to unpack nbf  file?
    No I did not unpack that nbf file
    2015-08-18T03:35:54+00:00
    Tell me how to unpack nbf file
    2015-08-18T07:01:11+00:00
    Change the filename extension from .nbf to .zip (do not append but change) and open it with any UnZip app. Did that work?
