I'm using Nokia 206 not nokia asha 206 does this work. I've followed ur steps and I'm stuck on step 3 after changing the backup file name. I'm trying to open the backupfile but is not opening and flashing a message as "File format not supported". What should I do?
Nokia 206 - disk space problems
I have a Nokia 206 dual sim phone, and it has a lot of DEMO games pre-installed. These are listed as System Files and i cannot get to remove them. Due to this, i am running very low on operational disk space, even after installing an external memory card.
How can i get rid of all the apps that are pre-installed and of no use to me, especially the DEMO games.
Please advice.
2015-01-25T08:46:42+00:00 -
2015-01-25T15:59:07+00:00 hello
I have a problem while upgrading whatsapp on my nokia asha 206.1. It says I should replace version 2.14.42 (which installed on my device) with version 2.14.61 bt the downloading is never completed. It always fails.
Please help guys
2015-01-26T12:55:35+00:00 we need the error message word for word. Furthermore, which mobile operator do you use, in which country?
2015-04-14T05:56:17+00:00 Thanks a lot, portgasdace!
You have made my day! You solution works perfectly on Nokia 2760 and on Nokia 206. (And as I understand will work on any other java-based Nokia phone.)
Respect!
2015-04-14T05:58:19+00:00 Try to change filename not on the phone, but copy it to the computer. And change there.
