I have another problem when i click "MY Apps" loading (1sec) then my nokia asha 206 restart and does not open.... Plz renspons me what i have to do...
Nokia 206 - disk space problems
I have a Nokia 206 dual sim phone, and it has a lot of DEMO games pre-installed. These are listed as System Files and i cannot get to remove them. Due to this, i am running very low on operational disk space, even after installing an external memory card.
How can i get rid of all the apps that are pre-installed and of no use to me, especially the DEMO games.
Please advice.
2015-01-19T21:36:21+00:00 -
2015-01-19T23:31:24+00:00 You don't have to deal with mobimb and stuff like that.
Just make a backup using Nokia Suite, reinstall software, and restore the backup.
No need to think which file you must not delete and stuff like that. I also used mobimb, but in the end you still need to reinstall the software...
2015-01-20T04:14:17+00:00 A new thread was created. Moved to Phone Applictions board.
2015-01-20T04:19:46+00:00 A new thread was created. Moved to Software Updates board.
2015-01-21T10:30:17+00:00 Hi
The person that did message 54, is the one you should speak to about these issues, because I have never tried back up, reinstall, restore, I've only tried the easy option, buy a new one.
I didn't even get up to trying any of the other appplications that was recommended earlier I just went by feedback of these applications. which obviously was extra work in using these applications.
Everything I tried brought no progress & it seems that this person knows what it is that there is no need to worry about, etc.
Thankyou
