how to reset phone if i forgot my lockscreen password
2014-01-04T02:10:00+00:00
i forgot my phone's lock screen pin and unable to unlock it
after reading a lot of questions regarding it i found that we should reset the phone and there is no other option than that .
so how to do it, mine is lumia 520
2014-01-04T04:35:19+00:00
Log into windowsphone.com and use the Find My Phone feature to set a new lock code
  1. Go to http://www.windowsphone.com and sign to the Microsoft account associated with your phone.
  2. Select "Find My Phone" from  the drop down menu that appears when you click on your name.  Or just go to https://www.windowsphone.com/en-us/my/find
  3. Click the "Lock" link
  4. Enter a new 4 digit PIN code and press the Lock button.
60 additional answers
    2018-01-18T11:17:03+00:00
    I am facing issue of Pin Forgot, but by following step one procedure, my issue is resoved. Thanks.
    2018-01-23T08:24:01+00:00
    I forgot my lock screen password and has been unable to unlock the phone their afterwards. My is a 500 series of Microsoft Lumina phone. please help me. How would I unlock it to use the data I had saved in my phone.
    2018-02-26T08:07:29+00:00
    this option is taking 2 long or not helping at all.
    2018-02-26T09:28:45+00:00
    نسيت كلمة السر في حساب:******@outlook.com
