What exactly does KB2952664 do?
2014-04-27T00:12:24+00:00
KB2952664 was published on April 22, 2014 and appears in my Windows Update List (I am running Windows 7 Pro - 64 bit).
The description of this update is vague:  "This update helps Microsoft make improvements to the current operating system in order to ease the upgrade experience to the latest version of Windows."
Anyone have more information on what this update actually does? If its sole purpose is to ease the "upgrade" from Windows 7 to Windows 8 (or 8.1 or 8.1 update), then I'll just permanently hide KB2952664 (I have no desire or intention to "upgrade" my Windows 7 system to any flavor of Windows 8).
If its purpose is to ease what would be a true Windows 7 upgrade to a yet-to-be-announced Windows 7 SP2, then I'll keep it (but still would like to have more information about what KB2952664 actually does before installing).
    2016-03-16T16:45:53+00:00
    BDSolomon,
    The free app called GWX Control Panel will make the registry settings you mentioned, and it will also make other settings to prevent Windows 10 from being installed.
    For more information about GWX Control Panel, see this site ...
    http://blog.ultimateoutsider.com/2015/08/using-gwx-stopper-to-permanently-remove.html?m=1
    2016-03-23T21:53:11+00:00
    KB3035583 (nagware) just appeared in my Win 7 Windows Update.  Seventh time it appeared.
    2016-03-24T00:09:07+00:00
    Barry,
    Thanks for the update.
    Those of us who do not want Windows 10 have to be constantly on the look-out ... because it appears that Microsoft will use any means possible to sneak Windows 10 onto our computers.
    I recommend that those who do not want Windows 10 do the following ...
    1. Keep your Windows Update setting for Important Updates set to "Never check for updates" (you can manually check for updates whenever you are ready ... see #4 below).
    2. Keep your Windows Update setting for Recommend Updates set to "Give me recommended updates the same way I receive important updates".
    3. Use the free GWX Control Panel app to insure that Microsoft does not slip a Windows 10 installation past you (either run it in monitor mode, or manually run the app right after you install KB updates from Microsoft ... see #10 below).
    4. Manually check for updates when you are ready. Microsoft releases their monthly updates on the second Tuesday of each month ("Patch Tuesday") .... I usually wait three weeks after that before checking for updates (to let the bugs get fixed and the updates Microsoft releases to coerce Windows 10 installation to be identified).
    5. Review Woody Leonard's site to see if there are known KB updates (from the previous "Patch Tuesday") that are causing problems, attempting to install Windows 10, etc.
    6. After you have checked for updates, review the list .... HIDE any updates that were previously hidden but brought back by Microsoft (such as KB2952664, KB3035583, etc, etc). HIDE any new updates that are known to be causing problems (see #5 above). Consider either hiding all non-Security updates (i.e., KB updates that do not have the word "Security" in its description) or (at least) doing thorough research to determine if you need any of the non-security update and that they (non-Security updates) do not cause any problems.
    7. Look through the "Important" tab (in Windows Update) and the "Optional" tab. Make sure that only those updates you want to install are checked ... and those you do not want to install are not checked.
    8. Install the updates that you want (I usually do them in small batches: Office updates, .NET updates, Windows Security updates, IE cumulative update, malicious software removal tool, etc).
    9. NOTE: if you have Windows Update set to "Never check for updates", and you close/exit the Windows Update window for any reason (such as to reboot after an update), and you go back to Windows Update (to install more updates), then you will have to "Check for Updates" again in order to see the list of updates eligible to be downloaded and installed.
    10. When all updates that you want have been installed, run GWX Control Panel to make sure Microsoft has not slipped anything past you.
    NOTE regarding IE 11. In most cases, versions of IE below 11 are no longer supported. I never use IE11 for browsing. However, Windows itself does use some of IE11's functions. So, it is important to keep IE11 up to date ... but I recommend using some other browser besides IE for surfing.
    Hope this helps.
    2016-03-24T01:00:11+00:00
    Have they ever removed the annoyware/adware from the IE security update?  We can no longer trust even their security updates, and I don't know what we do if they keep screwing with security updates.
    I FINALLY got GWX Control Panel, have it set to run periodically.
    I'm so proud.  I passed.  NO exceptions noted, I have so far avoided all their garbage.
    2016-03-24T08:52:52+00:00
    Barry,
    Hope this helps.
    1. Update GWX Control Panel regularly.
