Qualcomm Atheros Bluetooth not working with Windows 8.1
2013-10-21T16:45:54+00:00
I am using a brand-new Samsung Atib Tab 3 tablet (XE300TZC-K01FR). I have installed the latest windows 8.1 release and now cannot use the bluetooth keyboard anymore. Seems that the issue is coming from the bluetooth card drivers (code 10 error - cannot start). What should I do now ?
It is impacting dramatically my work productivity as I can now only use the virtual keyboard. Will a fix be published very very soon?? I do not understand why it is always such a pain with Microsoft products. No wonder the company is loosing marketshares.. I do not expect revolutionnary products but at least something that do work properly...
Thank you for your support.
2013-10-22T16:18:19+00:00
I had the exact same problem and fixed it myself. Here's how to do this:
Go to device manager and find the Qualcomm Bluetooth Atheros device
Then double click on it and on the drivers tab, select uninstall driver but make sure that you select "Remove driver from computer" or something to that effect.
Then rescan your computer by clicking on the small rescan icon on the top left of the device manager window.
The Atheros device will now show up as unkown device. Open it up and select install driver and don't select internet but select C: drive and check the subfolder box.
It will take a while but after a few minutes, it will install the right driver and then you need to repair your keyboard.
Cheers!
DL
54 additional answers
    2014-01-09T07:47:09+00:00
    This one worked for my Acer Aspire V3-772G too! Thanks!
    2014-01-27T17:00:18+00:00
    i faced the same problem with lenovo ideapad z510.
    i uninstalled qualcomm atheros bluetooth drivers. i didnt install it again.
    it worked like charm.
    just uninstall useless qualcomm atheros bluetooth drivers.
    2014-03-17T21:46:23+00:00
    Thank you so much. This would have been a personal last resort, but cause I saw your suggestion I tried it right away. Thanks. Now to actually connect my headphones.
    2014-03-24T01:32:39+00:00
    Hi everyone,
    If you have a Win 8.1 Machine with built-in Bluetooth from Qualcomm Atheros Communications, the Bluetooth may no longer work after you've upgraded to 8.1; this happened to me.
    If you go to Device Manager, there is a Bluetooth section and in it there is a thing called "Bluetooth USB Module."  Actually, the Qualcomm Atheros Communications Bluetooth is built into the Wifi Adaptor, but that does not really matter.
    Acer (but probably other manufacturers as well) have not updated the drivers for this device to Win 8.1 yet on their sites.  The Atheros website is also useless.
    I found the Win 8.1 Driver (64 bit) here:  http://drivers.softpedia.com/progDownload/Acer-Aspire-V5-573P-Atheros-Bluetooth-Driver-801305-for-Windows-81-64-bit-Download-306204.html
    I have an Acer Aspire Desktop, so I can verify that it works for Acer.  Might also work for other PC Manufacturers, but not sure.
    It's a big download (over 300 mb), but it fixed the issue for me:
    Download the zip file; extract all
    Open "Install CD" folder
    Find "setup" and run it
    Restart machine after it's done
    Good luck!
    Fix is confirmed to work on Aspire Model m5-581T. I had issues with my phone connecting to my aspire via bluetooth. This driver worked to connect the phone. Well done mate! Good show!
