No it shows what is stored in the Restore Points and allows you access.
It is not for creating, removing, or controlling a Restore Point.
I think your best bet is to use a full Reset and to be careful what you install.
As I said it is a useful tool.
Original Title: Let's start simple! Is there anyone from Microsoft out there?
For 6 weeks, I've been trying to sort out why my system restore points keep getting wiped out - something to do with VSS Server, I think. But let's forget that for now - all I want at the moment is a definitive answer whether VSS Server should be on Manual or Automatic. Some MS documents say one, some the other. If I can find out this, we can then move on to the next step of why it keeps getting switched off, regardless of which option is chosen. So SHOULD IT BE ON MANUAL OR AUTO? surely that isn't difficult to answer and must be known by MS.
Hi Linney,
Thanks very much for the message and I'll look into those links. I've not had any reply from Acronis yet. I hope I didn't sound aggressive in my reply - 6 weeks of getting no answers from MS don't help, nor do getting no answers from HP and Netgear ,while testing my mouse on another computer, as suggested by Logitech, blew up my laptop, so I've that to restore now as well. Maybe I'll be able to get some work done soon and earn some money!
Hi Rob,
2 last points for when I do a complete new install.
Thanks for all the help
at a high level. Cleaning out a few lines of code or even hundreds does nothing when the Registry
is GB in size. And worse Registry Cleaners usually remove entries that are needed. That removal causes
strange issues to even total system failure. These forums have thousands and thousands of examples
where issues were caused by Registry Cleaners or their other name of System Optimizers.
Microsoft says,
"The Windows registry is a database that lists all of the configuration settings that determine how Windows looks and behaves. Sometimes, settings that are no longer needed will remain in the registry in case they're ever needed again. There's nothing unusual about this, and this data is small in size."
Why I don't use Registry Cleaners
http://www.edbott.com/weblog/2005/04/why-i-dont-use-registry-cleaners/
Download Windows 8.1 ISO Using your Windows 8.0 Key
http://mcakins.com/2013/10/19/download-windows-8-1-iso-using-you-windows-8-0-key/
Download Windows 8.1 iso
http://philipyip.wordpress.com/download-windows-8-1-iso/
Download the Windows 8.1 ISO using a Windows 8 key and some simple trickery
You can also make a Recovery USB drive.
How to Create a Recovery USB Flash Drive in Windows 8 and 8.1
http://www.eightforums.com/tutorials/5132-recovery-drive-create-usb-flash-drive-windows-8-a.html
On Nov. 15, 2013 Windows 8.1 Back-up Media will be available for purchase. Newegg and
others will be offering the disc,
Windows 8.1 'Back-up Media' disc available to buy soon
http://betanews.com/2013/11/05/windows-8-1-back-up-media-disc-available-to-buy-soon/
Hope this helps.
Rob Brown - Microsoft MVP <- profile - Windows Expert - Consumer : Bicycle <- Mark Twain said it right!
O
In this part, Rob,
A recovery USB flash drive cannot be used to install Windows 8unless this is an OEM PC that came with Windows 8 preinstalled, and you checked the Copy contents from the recovery partition to the recovery drivebox at step 5 below.
This is the problem lots of people have - the manufacturers no longer bother to install the recovery partition. And the method described by MS to make your own doesn't work - it just makes a directory which can't be used to make the disk (dozens of threads on Google about this and I've tried it myself several times). My question is, in my reinstall, can I set up the partition that the manufacturer should have done? Do any of the other links you gave me allow this? otherwise it's not possible to make the recovery disk, only copy some repair tools to it
