Problem checking for updates - Code 80240442 - Windows Update ran into a problem
2014-04-08T19:18:08+00:00
Just updated to 8.1 update 1 manually hoping that it would clear an issue I'm having with Windows update, but to no avail.  (Oh - and the error message before the Win8.1 Update 1 was 80244FFF.  I think it's the same issue, just a new number.)
I've not been able to connect to Windows Update for over a month, and nothing I've tried has managed to reset it.
2014-08-13T22:37:43+00:00
bizarre, my update is working after months of failure. i am not joking. BUT only automatically. if i try to check for updates manually i receive the same error code and no updates
AND i believe i have the solution for all of these problems...
i needed to restart my modem. as soon as it had restarted, automatic updates worked. i think all who are suffering from this problem should at least give this a try. just unplug your modem, wait 30 seconds then re-plug in your modem or push the restart button. it is worth a try.
paz from mexico
129 additional answers
    2014-06-04T11:50:43+00:00
    Hello Paz,
    Thank you for your response.
    I would suggest you to try following steps and check if it helps.
    a. Press Windows + X keys and select command prompt(admin).
    b. In command prompt window, copy and paste the commands (all at once):
      net stop wuauserv
      net stop cryptSvc
      net stop bits
      net stop msiserver
      ren C:\Windows\SoftwareDistribution SoftwareDistribution.old
      ren C:\Windows\System32\catroot2 catroot2.old
      net start wuauserv
      net start cryptSvc
      net start bits
      net start msiserver
      pause
    c. Wait for the process to complete.
    d. Close the command prompt window.
    Now, go to Windows update and check.
    I hope this information helps.
    Thank you
    2014-06-04T12:52:53+00:00
    thanks so much for trying to help, but alas this did not work. One thing i really appreciate is the fact that you had me copy and paste ALL, i had tried this command prompt in the past BUT i copied and pasted each one individually. what a waste of time. thanks. maybe just maybe you have another idea. PLEASE.....
    2014-06-04T13:14:39+00:00
    an idea... could it be that i installed SECUNIA update software on my system and this is somehow blocking the ability to have microsoft scan for updates????
    2014-06-04T13:21:04+00:00
    Hello Paz,
    Thank you for the reply.
    It is possible that third party software may be causing the issue.
    You may uninstall it and check the issue. To uninstall it, please use these steps:
    a. Press Windows + X keys and select programs and features.
    b. Right click on the program and select uninstall.
    c. You may restart the computer, if required.
    If it does not help, then I would suggest you to perform system restoreand check the issue.
    Refer this article:
    How to refresh, reset, or restore your PC
    http://windows.microsoft.com/en-IN/windows-8/restore-refresh-reset-pc
    Note: When you use System Restore to restore the computer to a previous state, programs and updates that you installed are removed.
    I hope this helps.
    Thank you
