Problem checking for updates - Code 80240442 - Windows Update ran into a problem
2014-04-08T19:18:08+00:00
Just updated to 8.1 update 1 manually hoping that it would clear an issue I'm having with Windows update, but to no avail.  (Oh - and the error message before the Win8.1 Update 1 was 80244FFF.  I think it's the same issue, just a new number.)
I've not been able to connect to Windows Update for over a month, and nothing I've tried has managed to reset it.
2014-08-13T22:37:43+00:00
bizarre, my update is working after months of failure. i am not joking. BUT only automatically. if i try to check for updates manually i receive the same error code and no updates
AND i believe i have the solution for all of these problems...
i needed to restart my modem. as soon as it had restarted, automatic updates worked. i think all who are suffering from this problem should at least give this a try. just unplug your modem, wait 30 seconds then re-plug in your modem or push the restart button. it is worth a try.
paz from mexico
129 additional answers
    2015-10-24T08:46:04+00:00
    i tried this and worked perfect for me
