How to enable Conservation mode in the Energy Management on Lenovo Ideapad Z510
2014-01-12T18:35:26+00:00
Whenever I have my computer plugged in when the battery is above 70%, a notification comes up saying:
The Battery is charged to a high capacity
Staying above 70% capacity for a long period of time is adverse to the battery's health. Enable 'Conservation mode' in settings.
I have a lenovo ideapad Z510 laptop with windows 8 and I cannot find a conservation mode option for battery in settings.
Does anyone know where it is?
Original Title: Conservation mode
2014-05-27T15:45:28+00:00
I have a Lenovo G710 but I think enabling the Conservation Mode in different laptop models wouldn't make much of  a difference.   This procedure works for me and I believe it will work for you too:
1.  Click on the up arrow icon near the battery indicator located at the bottom right corner of your computer display.
  1. Once you click on the up arrow it will show some hidden icons not normally displayed on your taskbar.  Move your mouse around those icons until the “Energy Manager” text is displayed.
  2. Click on that icon and the Energy Manager screen will show up.  Then click on the small circular dialogue box located on the right hand side just above the big clock-like indicator.
  3. On the top right corner click on “Settings”. On the right hand side of the Conservation Mode is a switch like gauge.
  4. Move the switch from left to right with your mouse until you see an orange colored “I” appears. This shows that you have already switched on  the Conservation Mode.  To confirm,  you will see the Conservation Mode displayed near the electrical plug icon.
  5. Exit by cllicking "X" located on the top right hand corner of the dialogue box.  And you're done!
Hope this works well.  Good luck.
70 additional answers
    2014-10-09T22:45:29+00:00
    Great advise and great instructions, step by step. Who needs a Geek, when we have you.
    2014-11-05T17:59:01+00:00
    Worked like a charm.  Thx!
    2014-11-14T09:36:42+00:00
    I had the same question as my computer displayed the exact same warning:
    Would it be a good idea to keep my laptop on Conservation Mode at all times when it's plugged in to the charger? I almost always keep it on the charger because it just seems to make sense, rather than letting the battery run low, plugging it back in, letting it charge, unplugging it again, letting it run low again, plugging it back in again...
    Is that practice unhealthy? What's the best way to deal with this?
    2014-11-16T09:46:35+00:00
    Enabled conservation mode the way you described and made sure I have enabled it (battery stays at 60%, plugged in, not charging). after shutting down my laptop and starting it up again, conservation mode is not enabled and i have to re-enable it. most of times i forget to do that which may affect my battery health.
    Is there anyway that I can save conservation mode so the laptop stays at conservation mode even after shutting down and starting up?
