How to enable Conservation mode in the Energy Management on Lenovo Ideapad Z510
2014-01-12T18:35:26+00:00
Whenever I have my computer plugged in when the battery is above 70%, a notification comes up saying:
The Battery is charged to a high capacity
Staying above 70% capacity for a long period of time is adverse to the battery's health. Enable 'Conservation mode' in settings.
I have a lenovo ideapad Z510 laptop with windows 8 and I cannot find a conservation mode option for battery in settings.
Does anyone know where it is?
Original Title: Conservation mode
2014-05-27T15:45:28+00:00
I have a Lenovo G710 but I think enabling the Conservation Mode in different laptop models wouldn't make much of  a difference.   This procedure works for me and I believe it will work for you too:
1.  Click on the up arrow icon near the battery indicator located at the bottom right corner of your computer display.
  1. Once you click on the up arrow it will show some hidden icons not normally displayed on your taskbar.  Move your mouse around those icons until the “Energy Manager” text is displayed.
  2. Click on that icon and the Energy Manager screen will show up.  Then click on the small circular dialogue box located on the right hand side just above the big clock-like indicator.
  3. On the top right corner click on “Settings”. On the right hand side of the Conservation Mode is a switch like gauge.
  4. Move the switch from left to right with your mouse until you see an orange colored “I” appears. This shows that you have already switched on  the Conservation Mode.  To confirm,  you will see the Conservation Mode displayed near the electrical plug icon.
  5. Exit by cllicking "X" located on the top right hand corner of the dialogue box.  And you're done!
Hope this works well.  Good luck.
70 additional answers
    2014-08-08T16:45:39+00:00
    I have the same question as Rajnkant:  Is there any way to keep the computer in conservation mode?  I am successfully at getting it there following Ramon's directions, but invariably a couple days later I'll get the warning message again and find that it is turned off.
    Same here, darnit!
    2014-08-22T08:42:48+00:00
    Me too
    2014-08-27T14:14:35+00:00
    Thank you for posting this and clearly outlining the steps!  Very helpful.
    2014-09-13T18:08:09+00:00
    thank you for the easy to follow excellent directions
