Web camera not detected, imaging devices missing in device manager and webcam not working
2014-09-16T14:48:31+00:00
*Original Title: imaging devices missing in device manager and webcam not working
imaging devices missing in device manager and webcam not working  HI,      Iam using DELL INSPIRON 15R 5520, windows 8.1 64 bit.      Last day when i clicked on the camera tile it said 'to get started, connect a camera' and i found out that none of my apps and desktop applications could     use the webcam.Each time i get an error massage saying camera not detected.My webcam used to work perfectly till then.          And the 'imaging devices' entry is missing in device manager.
2014-09-17T10:21:35+00:00
Hello Prudhvi,
Thank you for posting your query in Microsoft Community.
Sorry to know you are facing inconvenience with the web camera not working on the computer. I can understand how frustrating it could be when computer and connected devices don't work as expected.
This issue could be because of the driver for the device is corrupt or needs to be updates.
Please help me with the following information:
  1. What is the make and model of the web camera?
  2. Have you made any recent changes to the computer prior to this issue?
  3. Do you get any error code, if so what is the exact error code?
4. Do you see a yellow exclamation mark in device manager for camera device in device manager?
5. Is the web cam integrated with computer or are you using an external web cam?
6. If you are using external webcam, what is the make and model of the webcam?
Method 1: Try running the Hardware and devices troubleshooter by following steps below:
1. Press “Windows Key + R”, type Control Panel.
2. Then type “Troubleshooter” in the Search box and hit enter.
  1. Select “Hardware and Sound” from the Troubleshooter Window.
  2. Select “Hardware and Devices”.
Camera app and webcams help
Refer (If you have problems with your webcam)
http://windows.microsoft.com/en-us/windows-8/camera-app-faq
If you are using a internal webcam, run the Diagnostics for Webcam Issues
Webcam Diagnostics
http://en.community.dell.com/support-forums/laptop/w/laptop/3557.webcam-diagnostics
Also refer to the article:
Using and Troubleshooting the Dell Webcam and Dell Webcam Central Software
http://www.dell.com/support/Article/us/en/04/SLN85507/EN#Troubleshooting-Webcam-Issues
Method 2:
Step 1: I suggest you to visit the computer manufacturer website and install the latest webcam drivers.
http://www.dell.com/support/home/us/en/19/product-support/product/inspiron-15r-5520/drivers
Steps 2: If webcam drivers are not available for Windows 8.1, you can install download Windows 7 driver and install it in compatibility mode. Refer to the help link to install the drivers in compatibility mode.
http://windows.microsoft.com/en-IN/windows-8/older-programs-compatible-version-windows
Hope this information helps, please reply with the status of the issue and the required information for any further assistance.
42 additional answers
    2015-06-27T05:16:11+00:00
    quickcam 846 windows it is a logitech
    2015-06-29T01:47:20+00:00
    Hello Jeannie,
    Thank you for the information.
    However, have you tried the above suggestions provided by me?
    If you haven’t tried yet, then please try them. I am sure that will help you.
    Please reply with the results, in order to help you fix the issue.
    Thank you
    2015-08-09T04:34:21+00:00
    i have the same problem..Imaging Devices is missing in the device manager and my webcam is not working "To get started, connect a camera " .Im using Sony Vaio Fit 15 ( model name: SVF15327SHW ) Windows 8.1 64-bit OS.
    2015-09-13T04:34:40+00:00
    What if you have a Toshiba  dose it the samething apply or not
